Barrel stove
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Barrel stove
    Posted: 17 Dec 2025 at 8:07pm
Hey guys I’m building a barrel stove. I’m actually using a large pressure tank rather than a barrel but same idea.
It’s going in a corner in my shop. I intend to dry stack concrete blocks on the wall beside it and the wall behind it.
How close do you think I can safely put it to the concrete blocks?
Has anyone ever tried an oil drip system on a wood stove?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2025 at 8:27pm
I have seen some oil drippers somewhere/sometime past on barrel wood burners so yes you can.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2025 at 8:36pm
Normal clearance to a non combustable wall is 12 inches i think.. I would stack the blocks an inch or two from the wood wall so it can breath... You can cut the 12 inches down to 6-8 inches if you put a box fan or squirrel cage blower and circ air between the blocks and the stove.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2025 at 9:00pm
YouTube has a few used oil drip system builds.
Also a few that wrap coils around the vent pipe to heat water.
You might fill the cement block with sand to increase it's thermal retention, and insulate the wall behind it better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2025 at 9:24pm
they also make  concrete panels that are 30" x  60" and 1/2 inch thick...  looks like drywall only concrete... couple pieces of that screwed to the original all would help--- with blocks in front..
Edited by steve(ill) - 17 Dec 2025 at 9:25pm
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2025 at 9:26pm
I would put bottom row of blocks so holes are horizontal and remaining layers with holes vertical. It will help with convection in the air gap mentioned above.
Use a needle valve for flow control and a ball valve right after it for shut off on the oil drip. Be careful of changing viscosity oil and that you don’t over load the fire. It can have an uncontrolled thermal event!
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2025 at 11:18pm
 Hey Good Buddy,,,,hope all is going well for you,,,,Clap
  Several years ago,,I started to build such an animal and after talking to a friend that had an automatic transmission shop and had built one to burn the transmission oil he saved.
 His biggest complaint was smoking up his shop on startup.
 He said he was  going to try something like an injecttion pump off a tractor that would atomize the oil at higher pressure for cleaner burning.
   His home made heater would leak at several places on both barrels and did not draft worth a flip,,,,!!!!
  It goes without saying,,every seam in the barrels should be leak proof to where you can snuff out the flame by closing the air intake when there is a run a way in the firebox,,,,
 Good Luck,,,!!! and don't be a stranger,,,,,LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2025 at 4:24am
I think I will put hardiboard on that sidewall before the blocks.
The back wall is just purlins on a pole barn.
I may add hardiboard to that as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2025 at 4:26am
I really like the idea of the bottom row stacked horizontal.
Would let a lot of air flow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2025 at 4:30am
Joe I’ll keep those thoughts in mind.
I ordered a “supposedly airtight” barrel stove door.
This will be a wood burner with possibly oil drip added to it.
I don’t think the drip oil burners work well with modern oil.
Post Options Post Options   Thanks (1) Thanks(1)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2025 at 5:46am
You should use 'roofing  tin' on the walls behind the stove. It'll reflect the heat and more importantly PROTECT the wall from sparks that might burn the barn down.two pieces in the corner would be fine.  I do like the Trombe wall of concrete blocks, with fan  to help maximize heat recovery and distribution.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2025 at 7:04am
I have 2 4x8 sheets of diamond plate heavy aluminum. Oxidized and ugly. I may screw it to the walls behind the concrete blocks. Would make wifey happy if they disappeared.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2025 at 8:29am
hopefully your insurance company will add their blessings to your plans! I had a Warm Morning wood stove in my shop several years ago that set about 10' from walls and they made me remove it! I even had double wall flu going thru the wall.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2025 at 8:38am
Concrete and heat do NOT mix, too hot and moisture that REMAINS Present in Concrete will rapidly Evaporate(IE Boil), causes Spalling.  Keep Distances as wide as possible for Cement based Products.
My intent here Should I EVER get wife Approval, a 1/8" Steel Pan beneath Stove we will Purchase, on Square Tube Legs 4" off floor with a Ring of either Steel Strap or Angle to Bowl the pan and for reinforcement.  At least 2' Longer one foot deeper, and foot to foot and half wider both sides.  The Walls surrounding the Corner where will sit will end up with a Fire Curtain of Steel or Aluminum with reinforcement at least as tall as bottom of Flue thru wall 3-6" off Walls and disassemble-able so can clean behind.
Overkill, why YES, need or necessity??  maybe not, Comfort Zone most definitely.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2025 at 9:09am
Is this pressure tank aluminum?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2025 at 9:51am
Thad, the idea of setting some blocks on their side to get air movement thru the openings sounds like a good idea on the surface.... but also realize you have just defeated the purpose of the blocks to reflect heat... If you put bocks on the back and one end wall, put the fan on the OPEN side of the stove and blow air around the back block wall to the side block wall, and out into the room..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2025 at 12:01pm
No
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2025 at 12:03pm
Good point. Was only thinking of putting a couple on the bottom row sideway. The fan idea will most likely take care of that.
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2025 at 2:41pm
According to a guy down the road, his was the best thing since Spam sandwiches. Then after the fire that burned 3/4 of his garage to the ground, I noticed it on his scrap pile and the words oil stove was dropped from his vocabulary. Give it some careful thought, cause if that fire gets past your dripper and to the reservoir (his was way too big I thought before the fire), gonna be a hot time in the old town tonight.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 26 minutes ago at 11:06am
I had a UL Listed wood burning heater in my shop and it seems Insurance Company gave me a choice have insurance or remove unit .
 I mentioned to adjuster I was replacing it with a Oil fired Furnace also rated by UL - then came the status it needed to be a minimum height above floor and along with furnace all electrical units (outlets , switches , or electrical connections needed to be above 4 ft above floor if any vehicles were stored or worked on in area .
  So overhead gas fired units mounted at ceiling height had to be used to meet Insurance inspection regulations .
  Seems OUTSIDE Placement of heating with wood could be used and just heat circulated into building would work . Something like outside hot water circulation boiler and radiant coil inside shop .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 51 minutes ago at 7:41pm
I have wondered if I could put this in a small concrete block building right next to the shop and just use a fan to blow heat into the shop?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 15 minutes ago at 8:17pm
Google up the word HASHA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 40 minutes ago at 11:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 44 minutes ago at 12:48am
You may want to add wood burner, wood heater or something similar to that, anything but the word eunuch.
Edited by Walker - 4 hours 41 minutes ago at 12:51am
