Barn find brought home
Gregg2408 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregg2408 Quote  Post ReplyReply Direct Link To This Post Topic: Barn find brought home
    Posted: 16 Apr 2025 at 10:49am
I am new on here, but, I just bought and got home a 1949 D motor grader. Drove it 7 miles home after some TLC.   I also own a HD4 loader.
the grader seems to be pretty straight it is plain Jane no lean wheel or power circle.  I plan to restore it, but it will also get usage it shaping up some terraces and finishing a waterway.  s/n is D 446 with the engine s/N  WD237353GA it appears it has been repainted twice both times yellow.  Question> should I go back to the original Orange or stay with the yellow?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2025 at 5:20pm
Welcome to the Forum Greg !!... NICE looking grader... are those tires as good of condition as they look in the photo ?  ......... when looking for engine parts, you know the motor is the same as the WD farm tractor..
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2025 at 9:56pm
Sweet old grader! I would love to have one but have never had enough of an excuse to get one... Figure I should get small dozer or track loader, like what you already had with your HD4. What are your plans for the grader?
And welcome!
EDIT: Sorry, didn't see your text below your picture about terraces/waterways. I like it.
My opinion is if you are going to paint it, put it back to original. Otherwise I'd lose no sleep leaving it as-is.
Edited by wjohn - 16 Apr 2025 at 9:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregg2408 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2025 at 7:55am
thank you, guys, yes, the tires are that good. the rears still had air in them although a bit low after setting almost 10 years in the barn.  the fronts came with it but had to buy tubes for them. it also came with a set of tire chains, which I will never use.  it also came with everything to install a S10 power steering unit minus hoses.  the front axle oscillation joint needs rebuilt, lift cylinders need resealed. and the engine needs some help. runs good but has no power. checked compression and all cylinders are around 70 psi. So, I will probably put an overhaul kit in it. I paid $1300 for it so I have some room to spend some money on it to make it nice.   Any suggestions or thoughts will be appreciated.
I have been around ACs all my we farmed and owned a C, CA, WC, WD, 190XT, and a model D that got sold 20 years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2025 at 8:22am
Welcome to forum.
Thanks for sharing
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2025 at 2:58pm
where abouts in KS?  we run alot of AC equipment between Abilene and Junction city south of I70
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregg2408 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2025 at 1:52pm
I am close to Topeka.
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2025 at 1:28pm
I had one years ago and made several modifications. If you have any questions contact me at 'donmcl@shaw.ca'.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 11:50am
I meant to comment on the tires. Look like new. It is essential that all drive tires are the same as they are all locked together for maximum traction.
