Barn find brought home |
Gregg2408
Topic: Barn find brought homePosted: 16 Apr 2025 at 10:49am |
I am new on here, but, I just bought and got home a 1949 D motor grader. Drove it 7 miles home after some TLC. I also own a HD4 loader.
the grader seems to be pretty straight it is plain Jane no lean wheel or power circle. I plan to restore it,
Joined: 11 Sep 2009 Location: illinois Points: 89217 |
Posted: 16 Apr 2025 at 5:20pm |
Welcome to the Forum Greg !!... NICE looking grader... are those tires as good of condition as they look in the photo ? ......... when looking for engine parts, you know the motor is the same as the WD farm tractor..
wjohn
Posted: 16 Apr 2025 at 9:56pm |
Sweet old grader! I would love to have one but have never had enough of an excuse to get one... Figure I should get small dozer or track loader, like what you already had with your HD4. What are your plans for the grader?
And welcome! EDIT: Sorry, didn't see your text below your picture about terraces/waterways. I like it. My opinion is if you are going to paint it, put it back to original. Otherwise I'd lose no sleep leaving it as-is.
Edited by wjohn - 16 Apr 2025 at 9:58pm |
Gregg2408
Posted: 17 Apr 2025 at 7:55am |
thank you, guys, yes, the tires are that good. the rears still had air in them although a bit low after setting almost 10 years in the barn. the fronts came with it but had to buy tubes for them. it also came with a set of tire chains, which I will never use. it also came with everything to install a S10 power steering unit minus hoses. the front axle oscillation joint needs rebuilt, lift cylinders need resealed. and the engine needs some help. runs good but has no power. checked compression and all cylinders are around 70 psi. So, I will probably put an overhaul kit in it. I paid $1300 for it so I have some room to spend some money on it to make it nice. Any suggestions or thoughts will be appreciated.
I have been around ACs all my we farmed and owned a C, CA, WC, WD, 190XT, and a model D that got sold 20 years ago.
Mikez
Posted: 17 Apr 2025 at 8:22am |
Welcome to forum.
Thanks for sharing
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 17 Apr 2025 at 2:58pm |
where abouts in KS? we run alot of AC equipment between Abilene and Junction city south of I70
Gregg2408
Posted: 18 Apr 2025 at 1:52pm |
I am close to Topeka.
DonBC
Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 947 |
Posted: 26 Apr 2025 at 1:28pm |
I had one years ago and made several modifications. If you have any questions contact me at 'donmcl@shaw.ca'.
DonBC
Posted: 28 Apr 2025 at 11:50am |
I meant to comment on the tires. Look like new. It is essential that all drive tires are the same as they are all locked together for maximum traction.
Gregg2408
Posted: 06 May 2025 at 12:51pm |
I do have a couple questions. Mine seems to be low on power. I know they are only about 39hp. But how well should they pull them selves in 4th gear. Mine will pull it on the level but any kind of grade it won’t. I checked compression and all cylinders are 70-75 psi.
Les Kerf
Posted: 06 May 2025 at 5:33pm |
I have never so much as touched one of those machines but methinks it may be just a wee bit tired
The compression is pretty even but low even for a WD engine. If it were mine (don't I wish!) I would just run it to maintain my 1/2 mile driveway. |
