Bar balance spring - 80T Trail Mower |
Farmer Tom
Topic: Bar balance spring - 80T Trail MowerPosted: 01 May 2017 at 11:56am |
I am in the process of reconditioning my 80T Trail Mower (Serial #T33xx), but getting ahold of a new "bar balance spring - A/C part #70804141) is not possible since it is no longer available from AGCO, so it looks like I will have to substitute another spring for it.
Does anyone have any specifics (O.A. length, O.A. diameter, spring metal diameter, tension factors, etc.) or a source for a replacement spring that I could use in its place? The current spring has been welded on and I am not sure it's even the correct one to boot. Any help/information would be appreciated. Thanks in advance; Farmer Tom |
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3132 |
Posted: 01 May 2017 at 6:53pm |
I have one of those mowers for parts is this the spring that pararells the lift cylinder?
Farmer Tom
Posted: 01 May 2017 at 11:31pm |
Gary;
No it is not that one; according to the parts/set up manual that spring is referred to as the "inner shoe balance spring". The spring I am looking for is at the rear of the mower and goes between the pto drive tailpiece and the twin-wheel drive unit. Thanks, Tom |
orangereborn
Posted: 02 May 2017 at 12:50am |
Tom...Your # is correct. I sent you a email with pics and measurements. Came off an 80T. There's more than one of those springs and some times they get interchanged. So give the info a look....Thanks...Dale
Orangereborn 964?? 192nd Ave New Richmond, WI 54017 715-247-3079 715-781-2055 |
