B steering wheel problem
JSHIVERS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JSHIVERS Quote  Post ReplyReply Direct Link To This Post Topic: B steering wheel problem
    Posted: 01 Jan 2025 at 10:05am
Happy New Year all.  I'm having a problem with my 1940 Allis B steering wheel.
I put a new wheel on this fall, and tightened down the center nut.  I thought things were all well and good until the wheel started spinning loosely.  I re-tightened it and the same
problem keeps occurring.   I'm wondering, should I add a lock-nut under the center nut
and will that correct this issue?  Or is there something else here I'm missing?  Any thoughts and help would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 10:08am
The end of the shaft is tapered and has a keyway. Did you lose the half moon key?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JSHIVERS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 10:15am
I'm pretty sure that the key way is there.  Now I'm questioning my
memory.  I'll check that.  Thanks!
KenBWisc View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 9:53am
If the key is in the key way, add a bit of thread lock before starting the nut. Those old threads seem to take beating when pulling the old steering wheel.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Post Options Post Options   Thanks (1) Thanks(1)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 12:38pm
If the key is in place, it will steer without a nut holding the steering wheel. Beyond that the problem might be deeper in the steering box itself.
