B starter conversion
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Topic: B starter conversion
    Posted: 05 Sep 2018 at 8:08am
I thinking about converting my B starter to a solenoid button start and adding voltage regulator to get rid of the cut out relay. Any one have a simple wire layout? Thanks.
39B 42B 48C SFW 52Cub Cub Cadet 70 S14 Speedex M14 Speedex S18 Speedex
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2018 at 10:12am
Suitable circuits would probably show in the CA manual:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
and in the appropriate section of the WC manual also in 10 pieces in that same Trees directory.
The voltage regulator includes a cutout relay but is a step forward in battery care. There are two ways a generator field can be wired, and the voltage regulator has to be correct for the generator field wiring to work at all.
Gerald J.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2018 at 11:32am
I get the voltage regulator.  I don't so much get the starter solenoid.  Added complexity without a benefit in my book.  A lot of people seem to have done it, though.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 8:52am
Complexity is my life.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 11:18am
I have both the old OE contact switch and some that have been converted to solenoid. The only thing I will say is that it is a lot easier  to open up the contact switch and clean the contacts that it is when there is a solenoid problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 11:59am
are you switching to 12 volts or retaining the 6 volt ?  Voltage regulator is a good improvement for the battery life... Alternator and 12 volts is even better.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 12:47pm
I have a B that has been converted. The way I bought it. It's still 6v. I hate the cut out and light switch. Mine is kinda all apart right now but if I can i will try to come up with a diagram for the wiring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 4:28pm
Frankly if you're going 1/2 the distance, might as well go all the way.
Convert to 12V, neg ground and put an alternator on.
You should replace 100% of the existing wiring anyway,alternators are cheap or free, 12v allows easy jump starting and cheap addons like lights,radio and winch.
Overall the 'complete conversion' might cost you $10-$20 more.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2018 at 10:12am
If your system is still 6V, a VR is a nice addition to the system for better charging and current usage.  Adding a Starter Sol. aids in Starter longevity due to voltage drop and also more current to the Starter for quicker cranking power. If moving to 12V's, we offer a nice conversion that gives you everything needed to do the deed. Drop by our website and check out of conversions. I also include step by step wiring instructions along with a color coded CAD wiring diagram. Also offer an optional Alternator mounting bracket if you don't want to fab your own...
Steve@B&B
This page was generated in 0.963 seconds.
