B Sluggish Starter
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: B Sluggish Starter
    Posted: 22 Jan 2018 at 3:37pm
After I overhauled my B back in 2016, the starter was slow to turn it over. I figured being a new engine and having a lot more compression, maybe that was normal during the break-in process. Then shortly after, winter arrived and it was still sluggish. I figured that was because it was so cold, and the engine had straight SAE 30 in it. After winter came summer, and it was still sluggish. (By sluggish I mean it goes "wump........whump...(dead silence for a couple seconds).....wump.) I know my battery is being charged, as when it's  running there are about 7 volts at the posts. It is also a new battery. I know it's good, because I used it in my '51 Chevy, and it turned it over really fast.
I'm thinking I need to take the starter in and have it checked. What do you guys recommend?
In the mean time I've quit using the starter and just crank it. Usually starts on the second pull, so it's not too bad. I'd just like the starter to be functional, in case it's needed.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2018 at 3:56pm
Where does it get warm to the touch when cranking it over. Could be loosing the ground. Try taking the starter position locking stud out and shining the end with a file or grinder then making sure it is in real tight. If the starter was weak when it stalled out when cranking and the voltage continued to it you would most likely see smoke.
A loose connection will fry itself to an connection and then loose it again. If it is not getting hot at the battery connections or where the ground to battery wire fastens to the tractor at the post then my guess is the locking stud which is where the starter gets its ground thru the tractor. You wouldn't feel much heat in that area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2018 at 4:25pm
I'll check it out when I'm home next weekend. Thanks, Dick!
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2018 at 6:11pm
Your starter bushings may be worn out allowing the armature to drag on the field coils. Might be time for a re-build.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2018 at 6:23pm
Both excellent suggestions. You might also check with a volt meter and see what kind of voltage the starter is pulling. Also check your timing. If timing is off you can have this problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2018 at 7:28pm
I offer rebuilding services if interested Creston.  If you went in an out turning over and engine for all those years as that thing did, you'd need a rebuild yourself!  LOL!  Drop me a PM if interested. I completely rebuild em' with new or rewound Armatures in em' n' all.
Steve@B&B
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2018 at 7:46pm
Battery cables from a walmart battery kiosk are way too skinny for a 6 volt starter. Can't afford volts of drop, they need to be more like 0 or 00 not 4 gauge that will spin a small 12 volt starter and small car engine.
Battery posts need to be cleaned twice a year in a 6 volt system, they corrode and the post and the connector both need to be cleaned until they shine, with a knife blade or a post cleaning brush or tool made for the purpose. Those posts can go a couple years in a 12 volt system between cleaning.
Starters do wear, brushes wear and loose spring pressure to make good contact with the commutator (and trying they can roughen the commutator surface). Bearings wear and the magnetic forces will make the armature drag on a field pole and that absorbs lots of the starter power. Windings can overheat and damage the insulation of the wires leaking to current losses from the windings.
Gerald J.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2018 at 7:58pm
And why not use 10W-30? 30W is so '60's!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2018 at 8:18pm
Gerald, yes, I'm aware of the cable requirements. It has good thick cables on it, not Walmart specials. I also cleaned the terminals a couple months ago.
Stan, why not go John Deere?  Allis-Chalmers is so 1985...Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 11:24am
Creston, take it out of the B and put it in a vise.  Put jumper cables on it and give it a whirl. Literally......LOL
If it sounds funny at all, it needs work.  If it pops and then slows down, it needs work.
I don't suppose there is a auto parts store close to you?  Most of them will test it for you for free.
The only thing hard about them is getting the brushes back in and you can do that easy enough with some toothpicks.  You could take a look at it and see what's wrong.
I agree with Alberta Phil.  I'm betting it needs rebuilding and you need to do it ASAP before you burn out the field coils (windings) or wear down the armature too much to where it won't function.  Also the commutator can get plugged with the wear from the brushes and short out.
NORMALLY it's just the brushes and possibly the brush holder is touching the comutator grounding it out.  That's SO easy to check out and if you're in there, replace the bronze armature bushings too.
I KNOW you can handle it.
It HAS to be the starter, as it turns over easily when you crank it and it starts right off, so it's not the timing or anything with the motor.
My guess is brushes and bushings.  Not the cables or timing or anything else.  At least I'D start with tearing it apart, cleaning, inspecting and new inner parts, including the springs.
Good Luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 2:31pm
If you pull the armature out, look at the copper windings and see if the coating is in good shape. Cracked or chipped can cause a problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 6:49pm
Thanks guys. I did a basic rebuild on the starter for my 8N back in 2014 so I have a little experience doing that. By no means an expert though. That one flat out quit after one of the brush soldering broke.
Ted, I do have a few auto stores nearby, so I may take it there if I don't get anything testing it on the bench.
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 8:52pm
I'm a moron when it comes to electrical issues, but my D10 was doing the same thing, before and after the overhaul. I had the starter rebuild and that made a major difference. Before the engine would barely turn over and over and over... Now it don't seem to even make a complete revolution before it starts.
