B Power!
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: B Power!
    Posted: 04 Dec 2011 at 4:26pm
I purchased a Oliver Plowmaster Model 100 today and gave the B a little workout. The nay-Sayers say that a B can't pull 2 bottoms but here it does! Granted the soil was pretty easy to work. Need to find a big field to play in!
My first time using a trail plow. Need to do some set up adjustments but otherwise for a former lawn ornament it did pretty good.
[TUBE]RX2MueRvu2I[/TUBE]
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 4:43pm
looks good Charlie... i gust  got to ask... what kind of air pressure do you run in those plow tires ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 5:52pm
Yep one side is flat. That will be fixed tomorrow.
Charlie
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 6:01pm
The kids are having fun & so are you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 7:43pm
Nice little B. Those are strong little tractors. Mine handles a two disc Athens plow just fine, especially after the front end of the tractor gets a little air under it.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 9:19pm
Charlie:
When you find a bigger place to play, try second gear.  It should handle it just fine if the ground isn't too tough.  My C walks the dog with the 2-12 Wiard pick-up plow and also handles a 2-disc Athens plow very well.  It's a blast to show up at a plow day and hear the nay sayers whisper about how the tractor is too small!  I just wish there were more plow days in our area.
