B Oil Breather Cap Stuck
MotorCityBear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MotorCityBear Quote  Post ReplyReply Direct Link To This Post Topic: B Oil Breather Cap Stuck
    Posted: 16 Jun 2020 at 9:11pm
1953 B that has been “neglected” a bit while life got in the way. Finally getting to it.
Before cleaning the carb out, which it needs, I drained the engine oil and installed a new oil filter.
Went to add the new oil and the breather cap appears to be frozen in place. I tried WD-40, a hammer, small oil filter wrench etc. but this thing is not budging. I am thinking I will need to remove the valve cover and hammer the cap from the underside.
Do you guys have any other suggestions for getting the breather cap freed up?
Rob
1953 AC B
Kubota L3901
Blairsville, GA
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 9:28pm
I had one like that... used 16 inch adjustable pipe pliers..... didnt look to  good when it finally came off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MotorCityBear Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 9:46pm
kinda what I am thinking. I guess I should order the new breather cap now, since it may not survive the “removal process.”
Rob
1953 AC B
Kubota L3901
Blairsville, GA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2020 at 5:53am
Rob,
Yes it is probably rusted in place. Removing the valve cover and trying to tap it out upside down sounds like it might work too!
Post some pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2020 at 8:55am
Use a strap wrench on it. Turn it back and forth as much as possible to loosen things up. if that fails, twist it off any way you can and replace it.
