B model radiator - pressurized vs non pressurized |
outlook6
Joined: 12 Sep 2009 Location: Austin, Texas Points: 64 |
Topic: B model radiator - pressurized vs non pressurizedPosted: 03 Apr 2012 at 4:42pm |
Does anyone have any information regarding when AC started putting pressurized radiators on the model B? I'd be interested in knowing at approximately what serial number the change was made. I need to replace the radiator on my 1940 B and believe it was originally non pressurized. The only sources I've been able to find for new radiators are all pressurized. Just want to find out if my serial number would be correct with the pressurized version.
Also if anyone knows of a source for the non pressurized version I'd appreciate getting that info as well. As always any help is greatly appreciated. Jim
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 03 Apr 2012 at 9:57pm |
look at the neck of the radiator. if it takes the same cap as the gas tank, it's not pressurized. You will also find the neck to be wide open without a flange for a sealing gasket as used on pressure caps.
I guess you can use a pressurized radiator but not use a pressure cap. Just remove the gasket. Bob
outlook6
Posted: 04 Apr 2012 at 8:17am |
Thanks Bob. I understand the physical difference between the two radiators and their caps. The radiator I have is unusable. My question is whether either would be correct for a 1940 B. I bellive it should be the non pressurized type, but the only new radiators I can find for sale are the pressurized versons.Regards, Jim
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 04 Apr 2012 at 11:17am |
These B and C types of engiines do not need to be pressurized to keep cool. The engine design didn't change from the begining to the end. If you use a pressure cap it would be best to not go over 7 pounds.
outlook6
Posted: 04 Apr 2012 at 1:32pm |
Dick, Now I understand. So it's the cap that makes the difference, pressurized or not, not the radiator. I assume any new radiator I buy will accept either cap.
Thanks again and regards, Jim
Tony.Or
Posted: 04 Apr 2012 at 4:58pm |
Don`t forget when you buy a new B , C , CA radiator it will have the new style Neck, made for pressure cap," ie" hooks from out side NOT inside like old originals.
So old style lever caps won`t fit new radiators. Tony
Gerald J.
Posted: 04 Apr 2012 at 6:09pm |
Its conceivable the tanks and tubes for a pressurized system are made of heavier metal to stand the pressure.
Its sure that with a 180 degree thermostat you need a pressurized system to keep it from boiling. Its sure that with a 180 degree thermostat you can't use an alcohol based antifreeze, you need a permanent (glycol based) antifreeze that also raises the coolant boiling point. Much of the antifreeze in the unpressurized tractor era was not called permanent. Thermodynamics indicate that an engine with a 180 degree thermostat is a bit more efficient because with a higher temperature cooling system less combustion heat is lost to the coolant. There are limits set by survival of valves, head and especially cylinder wall lubrication which still prevent going to higher coolant temperatures. It may be possible to find a none pressurized or very low pressure cap like 1 or 2 pounds to fit the replacement radiator. I'm sure a drop of solder in the right place or a bit of picture hanging wire or a 1/32" drilled hole can convert a 15 psi cap to nonpressurized. Just it won't look like a 1938 radiator cap. Gerald J. |
pumpkinman
Joined: 20 Jul 2011 Location: S.E. Michigan Points: 252 |
Posted: 04 Apr 2012 at 7:59pm |
None pressure rads. were used prior to tractor # B61222
pumpkinman
Posted: 05 Apr 2012 at 11:19am |
Have your old rad. recored if the tanks & frame are still good - or have your filler neck put on the new rad. |
