B Low Oil Pressure...Still
 Post Reply Post Reply Page  <123
Hockeygoon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hockeygoon Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2016 at 8:34pm
Originally posted by Gerald J. Gerald J. wrote:
Plus the additives in the modern oil will keep the engine cleaner and protect the bearings from corrosion from water in the oil making the steel against copper into a shorted battery.
Gerald J.
A good 30 weight HD oil will have all the additives and detergents that 10W30 has.  And will not break down nearly as fast as 10W30 under heavy use.  Just put 10W30 in for fall and winter use.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2016 at 8:39pm
Rotella has a HD 10w30 that is diesel rated I use it in my gas motors it seems to hold up well and has additives that I have been told help with the flat tappet on the old cams. Don't know for sure about the additives but it works well for me.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2016 at 8:43pm
I thought he just rebuilt the motor.. Everything is clean and new..
Yes.
pumpkinman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkinman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2016 at 8:45pm
I HAVE 5-Bs, 3 C/A s- 1 C -2 WDs  for the last 30 Yrs THEY HAVE HAD 15/40  SUMMER & WINTER AND HALF THE TIME YOU CANT SEE THE GAUGE BECAUSE OF DIRT.
         SIT BACK HAVE 2 FINGERS OF JACK AND A COLD  BEER
     IF IT BLOWS UP IT BE FROM OIL PRESSURE                    KENT
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2016 at 7:27am
Just last week, was down to 60 degrees maybe. Started up an old JD with SAE 30 in it. It usually runs toward the bottom of the medium pressure area. It was up in the high area for about 5 minutes until it warmed up, then back down to the M.
There's a reason the old gauges had a "NORMAL" range. As long as you're in that range your "normal"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hockeygoon Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2016 at 8:05am
Agreed. Normal is normal.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2016 at 10:41am
A modern automobile engine is much harder on motor oil than a D17. 10W-30 works just fine in an automobile engine. Todays multi-vis oils will outperform any engine oil of the 1960s. "Thicker is better" isn't true anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hockeygoon Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2016 at 11:05am
At operating temp 10W30 is the same as 30 weight - nothing "thicker" about it. What is "thicker" is the oil at start up in cold weather - that is why I recommend switching to 10W30 in the fall and winter. If you are using a tractor for long periods of time under high heat conditions straight 30W is a much better oil than 10W30.
SAE30 weight is more shear stable than 10w-30. The SAE 30 does not have any viscosity index improvers, the 10w-30 does. Multi viscosity oils have polymers added to a light base (in this case 10W) that breaks down over time and use. In conventional oils the more polymers added the less stable the oil is under high heat - especially over extended periods of time.
Above 40 degrees you gain little if anything using 10W30 over SAE30 weight while losing the stability of a straight weight oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2016 at 12:28pm
Here's something for you to ponder. In the Spring of 1978, I had a 7030 tractor I had just overhauled and had rented to a friend to put his crop in. I had the newest engine oil available at that time, A-C 15W-40 diesel oil. It was the same oil new tractors were coming with from the Factory. I was a little disappointed in the engine oil pressure, as it was only 44-45 psi at full load and at operating temps in the field. We ran that oil for about 50 hrs and switched to good old straight 30 weight diesel oil. To my surprise, our oil pressure increased up to 47-48 psi under the same conditions. Same tractor.....same oil pressure gauge.....same ambient temps each day. I've never quite figured out how SAE 30 was thicker than 15W-40.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2016 at 6:49pm
Something to consider about something that beats up oil is a 6.7 Powerstroke. 10-30 dino is recommended. Right now the 6.7 is the torque leader over GM and Cummins although the new Duramax is rated at 15 hp more. I see Ford coming out with a recall to flash them up to the Duramax.
Anyway both Ford and Cummins pulse the injectors in the exhaust stroke to dump fuel in the catalyst which results in fuel in the oil. Shear stability is definitely up to the task. The connecting rod bearings are not as wide as what's in the B125 engine. Only time I've ever see one puke is a programmer overfueling and over revving.
Oil technology has far surpassed even the 90s...
This page was generated in 0.270 seconds.
