B liner O.D. |
littlemarv ![]() Orange Level ![]() Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Oct 2017 at 8:45am |
Can someone with a calipers and a liner out of a B engine do me a favor? I need to know the O.D. of the bottom of the liner. Thanks much.
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
SteveC(NS) ![]() Orange Level ![]() Joined: 12 Oct 2009 Location: Nova Scotia Points: 663 |
Marv, I measured a brand new liner as 3.678 at the bottom and 3.712 up just before where the O-Rings go.
I also checked a used (but still usable) liner and it measured the same. Hope that helps. Steve |
Perfect, thanks a lot!
chaskaduo ![]() Orange Level ![]() Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Would these numbers be the same for my 1938 B, 1.9ltr - 116.1ci engine?
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5903 |
Prior to 1943 116 cu.in had 3.25 dia. pistons, 3.5" stroke 1943 and later 125 cu.in had 3.375 dia. pistons, 3.5" stroke Not sure about the liner O/D's. Gary |
I was thinking I would like to cut a sleeve puller disk.
That's what I need the OD for. I gave a machinist pal some scrap metal to make pullers for both a WD sleeve, and a B sleeve. But, the other day I put the liners in the B and never measured the bottom, and it's impossible to get to now!
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88334 |
you can take NEW oversize bore sleeves and put in a 116 inch OR 125 inch block....... so the blocks have the same bore for any sleeve. ... 3 1/4 , 3 3/8 , 3 7/16 overbore
What would be the recommended disk diameter be for pulling 116ci B sleeves?
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
The best pulling disk would have a shoulder turned on it to match the sleeve bore so it stays centered and the outside diameter less than the outside diameter of the sleeve.
Gerald J. |
