“B” governor issue
GfdMatt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GfdMatt Quote  Post ReplyReply Direct Link To This Post Topic: “B” governor issue
    Posted: 16 Aug 2019 at 5:35pm
Hey all,
Today my tractor died on me mid flight as I tried to increase throttle. I thought it may be a fuel delivery issue but I found that the throttle lever felt a little funny. I followed the linkage and found this with the governor. Does this piece just rest into the governor housing? Or is there something internally going on? Thanks
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 6:03pm
Supposed to be a press fit.  I took a big pair of Channel Lock pliers and squeezed it good.  That knurled it enough that driving it in, it hasn't fallen out in a while.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote GfdMatt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 6:14pm
Thanks Aaron, I did just that and it seemed to seat well without budging. I imagine that'll work. Now to get er started again...
 Is the small line going into the rod an oiler for the gears in the governor?
Thanks,
Matt
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 8:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote GfdMatt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 9:58pm
Thank you Gerald!
Post Options Post Options   Thanks (0) Thanks(0)   Quote GfdMatt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 12:21am
After getting the governor back together and resetting the throttle linkage, the tractor actually runs much better than it did before. I am
Now able to get more RPM due to the positioning. Thanks for the help guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 6:07am
That oil line helps lube the governor.
AaronSEIA
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 7:25am
The oil from that line dribbled oil on the gears and gets splashed around from the gears meshing as it falls down on its way into the pan.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 7:29am
I have some rebuilt covers for sale if anyone is interested.
