B fuel Level Check
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: B fuel Level Check
    Posted: 19 Apr 2011 at 1:02pm
So what is the tried and true method for seeing how much gas is in the tank for the B/C/CA?
Can't see in clearly enough to eyeball it. Need a long dowel or something and mark it.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 1:04pm
Yep, old fashioned stick gauge...
WD in kansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD in kansas Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 1:06pm
That's what I do on my WD. I have a special stick in the shop. No marks on it, I just know how full it needs to be to mow the place.
1950 WD, Duetz Allis 613
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 1:50pm
A piece of old yard stick tucks in between the seat cushion and frame on my B. An inch in the bottom goes way further than an inch in my 45. :)
Ron Eggen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Eggen Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 2:04pm
We always used the power shift wheels wrench handle on my grandfather's WD, but I realize that a B doesn't have one, so any dowel or like item would work.
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 2:21pm
The toolbox on my WD is just long enough to fit the gas guage (dowel), in.
George Davenport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George Davenport Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 2:43pm
I used a 14" wooden paint stirrer with a hole drilled in the top. Painted it with 2 coats of clear urethane and made notches and lines at each gallon. The first gallon is approx 1 1/2 inches up and each gallon thereafter is 1 inch higher and top is 11 inches (full).  You can also paint one with a flat paint and is more visable.
Greg (Hillsboro, OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg (Hillsboro, OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 3:45pm
My B is a crank start, so the crank makes a wonderful gas guage.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 4:54pm
Just keep plenty of fuel in, easy.
bikley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bikley Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 5:15pm
you never have to much gas the way i figure
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 6:30pm
We have 2 yard sticks hanging on the wall, use them on all of our tractors, except the "new" one !!!
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 9:30pm
I used a dowl rod cut down so it was about 3 to 4 inches above the tank. I then stored it along the steering column where the hand crank goes. Works well! Just make sure you put it back where its "made to go" instead of sitting it next to you on the seat! I had one decide that it wanted to taste dirt and it got ran over by the tire. It was a lot cheaper to replace then any part you get from AGCO though!!! LOL
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2011 at 12:01am
Stick hangin' on the shop wall by the door. Same "gas gauge' for all the tractors in the shed!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2011 at 9:53am
There's an old Army Aviator saying that says,"The only time you have too much fuel is when you are on fire."
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2011 at 11:03am
Standard paint stir fits in the B tool box.
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2011 at 1:33pm
Any thing except steel, don't want any sparks.
