B fan belt |
Kiwi ![]() Silver Level ![]() ![]() Joined: 23 Jan 2018 Location: New zealand Points: 390 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Sep 2019 at 11:12pm |
Hi all can anyone tell me what size fan belt I need for my Allis B with a 6 volts generator
Thanks in advanced |
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Might be in the specifications section of the shop manual:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf But might not be correct for a different era B from the date of that shop manual. You might be able to measure the length with a 1/2 or 5/8" wide steel tape measure. Tape should be the same width as the belt, 5/8" for a B belt. Gerald J. |
mdm1 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2677 |
This the Allis part # 70209656. No idea what the actual size is.
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3906 |
I have two 'B's with generators. Both belts measure 38 inches outside. One has a 5/8 wide belt and the other has a 1/2 in. The 1/2 in. one rides in the crank and generator pulleys better--about 1/16 in. below the outer edge of the pulleys. Both of these tractors get a lot of use.
Edited by Alberta Phil - 14 Sep 2019 at 9:09pm |
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5044 |
That AGCO number will cross to a GATES belt TR22373 which is 11/16X37-7/8.
