B Clutch adjustment?
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Topic: B Clutch adjustment?
    Posted: 12 May 2015 at 1:29pm
Is there some way to adjust the clutch on a B without splitting the tractor? I'm having to push past the stop to put it in gear after starting... Not sure How far I have to push it to disengage in gear, however..
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2015 at 4:32pm
You can adjust the linkage. remove the link from the clutch pedal, turn the rod you just disconnected counter clockwise to get more travel. There should be about 1/2" free play when the pedal is moved forward from the spring loaded full aft position.
If you turn the rod too far it will screw out of the through out bearing holder (called the shifter).
This is not really a clutch adjustment but a linkage adjustment.
