B Clutch adjustment? |
corbinstein ![]() Orange Level ![]() Joined: 31 Jul 2014 Location: Oklahoma Points: 796 |
![]() ![]() ![]() ![]() ![]() Posted: 12 May 2015 at 1:29pm |
Is there some way to adjust the clutch on a B without splitting the tractor? I'm having to push past the stop to put it in gear after starting... Not sure How far I have to push it to disengage in gear, however..
wbecker ![]() Orange Level ![]() ![]() Joined: 29 Oct 2009 Location: STL Points: 837 |
You can adjust the linkage. remove the link from the clutch pedal, turn the rod you just disconnected counter clockwise to get more travel. There should be about 1/2" free play when the pedal is moved forward from the spring loaded full aft position.
If you turn the rod too far it will screw out of the through out bearing holder (called the shifter). This is not really a clutch adjustment but a linkage adjustment. |
