B/C Hydraulic cylinder repair
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Topic: B/C Hydraulic cylinder repair
    Posted: 26 Aug 2010 at 10:42am
While dealing with the D-19 ps pump I also checked into the availability of  seal material and a new shafs for the B/C hydraulic cylinders. $35 plus shipping! Check with your friendly neighborhood hydraulic shop or, E-mail me.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 11:49am
That is a pretty good price Ken. If I remember right, when I did the Build a B pump and cylinder, the chrome rod for the replacement was $20. Then I had machine time involved to turn and thread the rod. The packings were about $8 too.
kofted View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kofted Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 3:29am
Can I rebild the hydraulic cylinders that are under the rear end on my WD? Where should I go or look for parts?
Karl
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 7:45am
If the rods are OK, you can more than likely tighten the packings a bit. These are chevron packings and need to let a small amount of oil weep by to keep things lubricated. If you are out of travel on the gland nut, new chevron packings are available from places like Motion Industries. Order by rod size and bore size of gland. You also need to know the stack height.
 If the rod is pitted or scarred up it will eat up new packings. I have made my own replacement rods from chrome stock and don't know of off the shelf replacements.
This page was generated in 0.590 seconds.
