B, C, CA thrust bearing question
ktm911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ktm911 Quote  Post ReplyReply Direct Link To This Post Topic: B, C, CA thrust bearing question
    Posted: 04 Jul 2015 at 9:53am
I had to get a new crank after the old one had its thrust bearing wear a pocket into the crank. It had new bearings in it (what looked like new) and the thrust one was badly worn.
It only had half a bearing with a thrust surface. Is this normal, or should both halves have a thrust surface on the sides?
Thanks for the help
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2015 at 10:40am
Yes: The B,C and CA engines only have a single shell as the thrust bearing. If the machine shop did a correct job of grinding the crank, the front journal should be properly re-sized to fir a new bearing shell after the timing gear is installed.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2015 at 3:08pm
If you look close at your block you will find that it is not made for the thrust bearing shell.
Edited by Dick L - 04 Jul 2015 at 3:09pm
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2015 at 6:03pm
If end play is excessive with the new thrust bearing in your rebuild kit the crank has to be welded up and reground to speck.
If I remember right the new thrust bearing in the last rebuild kit I used was shorter than the one it was meant to replace. I just used the old one to fix the excess end play.
This page was generated in 0.071 seconds.
