b block cracks
podunkpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote podunkpuller Quote  Post ReplyReply Direct Link To This Post Topic: b block cracks
    Posted: 10 Jun 2011 at 8:39pm
 Just bought gramps B back from a cousin. It has sat outside with an open exsaust for eight years! After blowing the water out of the cyls with the air hose and draining 16 quarts of water out of the drain pan, I filled each cyl with p b blaster. for eight days I hung a weight on a wrench from the pto and changed direction every morning and night with a lot of rocking in third gear. No dice still stuck. I pulled the motor and tore it down, off to the machine shop in the morning with the head, block and crank. The raidiator and water jacket had good antifreeze in it, but there are cracks between the cyl at the top of the block, I think and have had other such cracks on other blocks. the head gasket should seal the cracks and the head and head bolts should keep it from opening up when assembled but I'd like some other opinions when the machine shop would like to stitch it for only $600. All I want is the water jacket checked and the deck checked. then clean and check the crank new guides in the head and it'll be all set.
310, 2 B's, C, 2 WC's, 2 WD's, WD-45,D-14, D-17 gas, D-17 d IV, 190
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 9:14pm
So are you taking the block to a shop with the pistons stuck and the sleeves still in it? I would at least beat the sleeves out and then get the pistons out to save the rods. through the rest in the scrap tub if they aren't any good and buy a complete kit with pistons, sleeves, and rings.
There are more of the BE and CE blocks cracked between cylinders than there are ones that aren't cracked. Don't wast money on stitching it. If there are cracks down in the bottom where the o-rings seal the sleeve, find a different block. You might even find one that doesn't have cracks up top for way less than the stitching would cost.
 Don't even think about putting it back together without replacing the o-rings on the sleeves.
Edited by CTuckerNWIL - 10 Jun 2011 at 9:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote podunkpuller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 9:23pm
If the block checks out Ok and the crank is all right I'll be ordering a whole kit. pistons sleeves,rings main and rod bearings and the valve train. I don't intend on having the block stitched , just wanted some other motor heads to back up my opinion when I drop off at the machine shop in the morning.
