B 5- bolt hub swap |
KenBWisc ![]() Orange Level ![]() Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1184 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Aug 2012 at 8:30am |
Thanks to Bill Long for his input!
I'm wondering if anyone has switched out the splined axles on an older B for then newfangled 5- bolt? Can they be directly replaced or do you need to change out the bull gears and/or entire final drives? |
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9659 |
I have a '39 B with a splined adapter to 5 bolt on one side. It has a flatter center than a C dished center. I hope to find another someday. On the front it has one riveted wheel/hub and on the other it looks like they removed the rivets and threaded the holes for small lug bolts.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87884 |
KEn, the axles are interchangable if you can find one. Same bull gear, same installation. Different hub.
Scott(SC) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Starr, SC Points: 397 |
Will a CA hub switch out with a B or C?
MikeinLcoMo ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: west plains mo Points: 620 |
I've got a set of 5 bolt finals off a '48 B that need to go. Mike. Cheap!!!
Thanks Steve!
1953CA ![]() Orange Level ![]() ![]() Joined: 01 Jan 2011 Location: Burlington, WA Points: 505 |
I've got a pair of spline to 5 bolt adapters in perfect shape that I may sell?
Andrew
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support" |
