ATF vs Hydraulic Fluid in D17 s4?
JBergie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JBergie Quote  Post ReplyReply Direct Link To This Post Topic: ATF vs Hydraulic Fluid in D17 s4?
    Posted: 27 Sep 2019 at 8:26pm
I'm sure this is a question that's been covered before but I couldn't find it off the bat.
My D17 s4 has a pto leak and before I fix it, I need to use it! So I thought I'd top off the fluid, but am not 100% sure if best to use ATF or hydraulic. Pros and cons to each. (Isn't the reservoir shared?) Thoughts?
D17 Series IV
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 8:34pm
Universal hydraulic.        MACK
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 9:12pm
ATF is too thin. Use hydraulic fluid
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 9:16pm
Make sure it has the 821 specification.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 10:21pm
821 spec is nice, but not a requirement for a D series........... any economy UTF is OK.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2019 at 7:45pm
I was under the impression that the D-17 Series IV had basically the same hydraulic system as the 170 and did require the 821 spec oil. Am I wrong?
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2019 at 8:34pm
You are not wrong WF.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2019 at 8:04pm
Is it leaking out the rear around the PTO? If so, that reservoir is not shared with the hydraulics. The Power director and hydraulics share oil but the trans and rear end is separate. Having said that you should fill both reservoirs with 821 oil.
Mosin9130 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mosin9130 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2019 at 8:37pm
Thread discussion is perfect as I’m about to change fluids on my D17 IV but I wanted to verify a couple of things. Per the operators manual:
Power director and hydraulics - type A auto trans fluid
Transmission and rear gears - SAE 80 transmission fluid
Considering the quality of modern day fluids, the appropriate fluid to replace BOTH is universal hydraulic fluid (821 spec)?
Edited by Mosin9130 - 29 Sep 2019 at 8:43pm
'56 WD 45...'63 D15 II...'66 D17 IV
