anyone know?
allismanamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Topic: anyone know?
    Posted: 02 Jun 2012 at 10:29pm
were i can get a new oil breather bowl for my allis chalmers c engine i was cleaning mine out today and held it up to the light only to see little pin holes where it has rotted out. should i just tuck a k&n oil air filter in the pipe under the hood off the breather? also do the original breathers  really do good job my motor is brand new and want the best for itBig smile thanks all
~AMP~
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 10:52pm
My WC was like that after I got all the crud cleaned off. It has a coating of gas tank liner in it now and works fine.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 6:57am
I have soft soldered a few of them successfully.  If you're careful, you'll never know it was done when you're finished.
EdK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EdK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 9:06am
Not sure if it will work but you might try the spray on rubber stuff. I've seen it on TV and similar stuff at Home Depot, made by Rust-O-leum".
EdK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EdK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 9:25am
I replaced the oil can filter with a K&N cartridge filter. I enclosed it in a metal container, (soup can), for protection. Since this is only my casual use tractor I have yet to change or clean the filter after about 2 years. Not original but practical.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 10:39am
JB Weld
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 11:42am
clamp style bowl NEW is about $19.00 on our site.   www.djstractorparts.com
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 2:01pm
All C's originally hand the 2 snap clips for the bowl which is different than the ring clamp bowl.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 2:39pm
I used J B Weld on my B . It,s been on about 4 years.
