anyone installe a calc-an-acre on 4wd?
gleaner000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gleaner000 Quote  Post ReplyReply Direct Link To This Post Topic: anyone installe a calc-an-acre on 4wd?
    Posted: 05 Apr 2012 at 5:32pm
has anyone installed a calc-an-acre on a 4wd? I bought one from shoup for our old horse with no speed sensor. how many magnets did u use if so?
thanx
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 6:33pm
I installed dozens of these years back on the Tobacco harvesters we made. I think we used 6 magnets on a torque hub. 5 or 6 will work as you put the calc into a program mode and drive the distance after installed onto machine over a measured distance. This will calibrate the unit to the actual speed.
Yea, I can fix that.....
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 8:12pm
The more you use the more acurate it will be. I put one on my Kawasaki Mule and found that 2 magnets were not enough to measure accurately. I went to 8 and that solved the problem, I'm now accurate to .2 foot. If you can put them on the hub at least 4 will give you a decent reading.
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 7:01am
I have one on my Steiger pta280, glued the two magnets to the front driveshaft., Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote gleaner000 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 9:31am
mike,
does the driveshaft method work well?
