Any tricks to remove a freeze plug?
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Topic: Any tricks to remove a freeze plug?
    Posted: 01 Jan 2012 at 10:32am
Have a one inch freeze plug on side of my engine block of my Ferguson that is seeping and I want to replace it.  Any tricks to remove it?  Just have fear that I will knock in into the water jacket to never be seen again.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 10:48am
Once you knock it into the water jacket just grab the lip with channel locks and pull it out. It won't go far the area inside the water jacket is not that big.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 10:48am
  pierce  with an  ice pick, insert a screw then pull with a prybar, claw hammer , or whatever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 11:01am
Thanks guys.  Think I'll try the ice pick first.....................now where's the wife's ice pick..........sush now, don't spill the beans.  She needs a new one anyway.
1968 one-seventy
1956 F40 Ferguson
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 11:19am
Just knock it in like Dakota Dave posted.
It won't go anywhere.
It will turn sideways and grab it with pliers and pull it out.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 11:44am
Everyone was correct and it's out!  THANKS!  I drilled a small hole and inserted a sheet metal screw and then grabbed it with vice grips.  I was able to bow it out before the screw pulled out.  Repeated with a larger screw and bowed it out more before it also pulled out.  Then I took a screwdriver and hammer and pushed one side inwards which pushed out the other side.  I grabbed it with plyers and out it came.  A little nerve racking as there was plenty of room for it to drop to the bottom but it stayed in the hole and just spun sideways so I could grab it.  Now to order a couple of 1 inch plugs.  I know I'll just need one but my luck always seems to not be with me if I just get one.  LOL
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 11:56am
 Any time I need to be certain a screw will hold in thin metal I punch the hole with a pick as it rolls the metal and gives a much better grip than a drilled hole. Anyway glad you accomplished the task. Take the rest of the day off.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 2:54pm
on the B head they came out easy becuase they were rusted up bad.  Poked an old srewdriver thru and they pried right out.   Bad deal was I had just had the head redone at a machine shop and the guy did not replace them.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 3:01pm
Two types of plugs , one is cup type and other is the disc type are used in different engines . One just fills a straight hole and other has a machined stop in the casting .
Removal of each and instillation of each differ.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 5:15pm
Make sure to use a good sealant on the new plug, like Permatex #1A
Still in use:
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2012 at 11:56am
