any tips on buying a C?
didgood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote didgood Quote  Post ReplyReply Direct Link To This Post Topic: any tips on buying a C?
    Posted: 02 Jul 2012 at 10:11am
Found a C that I am kind of interested in. What should I check out before pulling the trigger?
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2012 at 10:16am
Narrow front?  I like to drive and check for wobble in the front wheels.  Also they seem prone to gas tank leaks, at least to me!  Should have hydraulics.  Good rear tires is nice!  Foot brake conversion is a real plus, but you get used to the hand brakes eventually, if not!
Post Options Post Options   Thanks (0) Thanks(0)   Quote didgood Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2012 at 10:27am
Thanks. Yeah narrow front.
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2012 at 11:14am
Check oil, and you can tell a lot about a man from the tool box, LOL!
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote didgood Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2012 at 12:10pm
True. Has hydraulics and bolt on rear rims. Did all of the bolt on rims have foot brakes?
allischalmers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmers Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2012 at 12:36pm
My c is a 1945 and it has bolt on rear wheels with foot brakes but i have problems keepin my battery charged its a six volt system with n 8 volt battery
WD45,C,3 B's
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2012 at 12:59pm
Check and see if the brake pins are drilled on both sides of the housing. Makes it alot easier to get out to replace the brake bands. Make sure the intake/exhast is in good shape and the end holes are not broke off. See how much play is in the steering wheel. A little is expected  but more than a fist worth will need looking in to. Great tractor to have around.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2012 at 10:01pm
All model C tractors had bolt on rear wheels with the rims fastened with excentric clamps
Model C tractors after serial # 5756 (mid 41) had foot brakes.
Check for steering wheel slop, oil leaks, pull oil stick looking for water, and other items mentioned by others.
Great little tractor, lots of power. It's a handy size. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote didgood Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 6:14am
Thanks to all
