Any Mauser action fans on here |
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9711 |
Topic: Any Mauser action fans on herePosted: 15 Jan 2026 at 5:36am |
I have a question.
I recently bought another Mauser in 22-250 I plan to add a filler in the back of the mag well. Where would I find a short action spring and follower for this project? Could I cut down the factory follower? |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35202 |
Posted: 15 Jan 2026 at 6:11am |
So are working with either a Rechambered action or Re-barreled? Mag well is likely for an older 7 or 8mm?
I own a Spanish Laguardia Rechamber to 7.62 x 51(.308), does not appreciate some projectile styles, Round Nosed especially. Bolt throw at times will also eject a new or next cartridge rather than feed it.
Thad in AR.
Posted: 15 Jan 2026 at 6:50am |
Yes it’s an old WW2 98 large ring Mauser.
iOS been rebarreled to the 22-250 I ordered a magazine filler to shorten the depth(front to rear) of the mag well. I’m looking for a shorter spring and follower which are also shorter front to rear. The filler goes in the rear of the mag well. |
Les Kerf
Posted: 15 Jan 2026 at 11:00am |
Seems like you will need a different ejector as well to deal with the shorter brass. Lots of good info in the gunsmithing section at www.castboolits.com
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13752 |
Posted: 16 Jan 2026 at 11:14am |
Hey Ole Buddy,,,can you give me a call,,? my dang phone took a tumble and lost your number,,,
Thad in AR.
Posted: 10 hours 34 minutes ago at 8:13am |
I’ve had some extra time this weekend with the weather. I’ve done a lot of reading and studying on how to make this ole Mauser feed 22-250.
I set it up ion the bench with lots of light and a head lamp to watch just what was happening. I noticed the front of the follower would hang up and not popping all the way up. I removed the follower and gave the sides a good cleaning and a quick polishing. Put it back together and it still hung up. I pulled it apart again and dropped the follower. This time the spring fell out of the follower. I didn’t know which end went where but I put it back together. This time the follower was pushed back from the feed ramps about a quarter inch. I pushed it forward but it kept resting 1/4” back. I switched the spring around and it held the follower forward like it was and still kept hanging up. I went to the safe and grabbed my 25-06 which is built off the same action. I looked in there and the follower sets back about a quarter of an inch. I swapped the spring around again and the follower set back 1/4” I soaked 3 rounds and it cycled perfect. Tried it several more tries and not one makfunction. |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8810 |
Posted: 9 hours 17 minutes ago at 9:30am |
Sounds like a WIN!
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54911 |
Posted: 3 hours 4 minutes ago at 3:43pm |
You'll like the 22-250. I have an interarms mark X in 22-250, with a cheap b&l 25 power scope on it. With hand loaded and matched ammo, I got a groundhog at 400+ yds. Aimed about a foot and a half high, and nailed him through the spine, while he was standing up, looking right at me...
