Another what's it worth....D14
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: Another what's it worth....D14
    Posted: 18 Aug 2012 at 2:55pm
Looking at a well worn D14 with 400the loader. Tires ok, paint nearly non existing but not rotted out. Needs a radiator and the front axle is pretty much junk and has been repaired. Really tough to steer also. No power steering. Also needs the Power Director adjusted possibly. Seems to slip a bit in low. How hard is the PD to fix? Whats this thing worth? He's asking 1500 obo.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2012 at 3:39pm
Im curious ....the loader is full hydraulic ....400's were trip buckets weren't they? This one has a hydraulic bucket.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2012 at 3:50pm
Believe the 400's were trip buckets but I could be wrong. I would be more curious about the hyds.D-14 could only run a trip bucket from factory. A lot of people added hyds by PTO pump or adding one to front. Very handy tractor with 2 way hyds and loader.
cost ; with what you are describing and the work it needs I would say 1000.00 , loader is worth something but radiators are not cheap and PD can add up also depending what is wrong
Was thinking 500 but sounds too low
Edited by Pat the Plumber CIL - 18 Aug 2012 at 3:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2012 at 4:12pm
It has a front pump
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2012 at 4:25pm
400 series loaders are fully hydraulic with a front drive pump. If the loader is not bent and welded up, I'd say the value of the package is in the loader not the tractor.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2012 at 5:32pm
400 Series loaders have 2  lift cylinders with 'down pressure'  and 2  'double acting' cylinders on the bucket.
Complete loader could be worth a $1,000 by itself if it was in decent condition.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2012 at 6:14pm
Anyone have a decent radiator laying around?
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2012 at 7:01pm
How bad is the radiator, can it be repaired?   When mine got "eaten" last year on my D15, I was happy to find a good used one for 250, as recoring my old one was gonna cost 350.   I would see if he would let you take the side cover off of the power director and look at where the shims are.   If there is alot of shims in the high and low side, it might just need some adjusting.   If most of them are already in the middle, you are now talking about splitting the tractor and finding another good used PD clutch or rebuilding yours and that's not gonna be cheap.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2012 at 8:31pm
Someone put a car radiator in it so it overheats pretty quick....just not enough radiator.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2012 at 8:54pm
Have 3 for sale . Ryan 402-469-1738
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2012 at 9:36pm
