Another Model C
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: Another Model C
    Posted: 27 Aug 2025 at 12:02pm
A 'Friend' of mine showed up last Friday with this Model C on his trailer and refused to leave without unloading it Tongue
The engine is stuck,  the tires are poor but they hold air, it rolls freely and the brakes seem to work, and the transmission shifts into all gears. The radiator is either brand new or has been rebuilt, it has a new temperature gauge and a new oil pressure gauge. It also has a 1-3/8" PTO shaft.
ACinSC View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 12:06pm
My kinda friend!!
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 12:08pm
Looks like it’s been in a sand storm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 12:24pm
The color doesn't show well in the photo but it was painted silver Dead
He got this tractor thinking it would be a good parts machine for the derelict Model C I have been tinkering with, trouble is, this one looks to be in MUCH better condition Big smile My Grandson is already making plans for it Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 7:27am
Grandson got the engine unstuck yesterday afternoon; it rotates freely with the handcrank and makes enough compression to push your finger off the spark plug hole on all four cylinders.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 8:59am
That does look better than the other tractor - and now the engine is free. What's the serial number?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 3:31pm
82029
I think that puts it as a solid 1949 model?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 3:37pm
Originally posted by Les Kerf Les Kerf wrote:
82029
1950! That should be within the last couple thousand built - about when they were changing over to the CA. I was guessing it was a later model so that makes sense. I'm not sure what year they went to 1 3/8" PTO shafts and AGCO's parts book doesn't show a SN break.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 3:50pm
my 1940 B had a 1-1/8 pto... my 1942 had a 1-3/8 pto... Dont know if it was original, but that what i got..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 7 minutes ago at 1:54pm
It runs!
(kinda sorta) LOL
A fresh set of plugs and a borrowed magneto from Mr. Cato's tractor got it going. I did a very minimal cleaning of the carburetor (it actually looked pretty good) and was able to hand-crank it to start. It wants a whole bunch of choke to keep running and there is significant exhaust blast blowing down behind the manifold so I suspect a manifold leak. But it makes noise now!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 1 minutes ago at 5:00pm
Grandson managed to drive it about 50 yards to get it to the shop. It doesn't need any choke so long as it is kept throttled back, so it putt-putted in first gear quite nicely. I may be wrong about the manifold leak as it looks like it was just burning off some oily reside. More investigation is warranted.
The engine sounds good and doesn't smoke. The oil pressure is in the upper region of 'NORMAL' on the gauge; I am draining the oil which is nasty black so a fresh filter will likely drop the pressure a bit.
We didn't run it long enough to verify the temperature gauge.
The transmission is noisy which isn't surprising considering the fact that there is no rubber boot on the shifter and the transmission was full of mostly water. I filled it with ISO 46 hydraulic fluid because that's what I had available. The PTO and hydraulic pump seem to work, the cylinder extends nicely but has nothing attached to push against. It does have the little two-way valve to allow running different circuits. The belt pulley leaks oil.
The starter is AWOL and the generator appears to be just a placeholder, the wiring is junk.
All in all I am quite pleased thus far Big smile
