An XT ?? |
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: An XT ??Posted: 21 Sep 2021 at 5:51pm |
I drove past a farmstead that I knew had a series 1 XT on the property (with a cab) as I've driven past the place for several years. I recently saw the RH side of the tractor parked close to the road and saw a circular "cover" on the side of the lower/front sheet metal
?? I've seen pics on Tractor House listings but never gave it much thought, what is the purpose of the round hole ?? Thanks
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 21 Sep 2021 at 5:59pm |
Air filter access.
DougG
Posted: 21 Sep 2021 at 6:00pm |
Air Filter- some had hinges - was a crude way to do it but it worked
FREEDGUY
Posted: 21 Sep 2021 at 6:15pm |
Thanks guys, I never dreamed of the A/F access. Did the "grill" not remove as easily as the series 2/3 ?
injpumpEd
Posted: 21 Sep 2021 at 7:03pm |
grill is essentially the same, just difference in appearance, but the element was too long to get out of the air cleaner without the access hole. The hinged panel is on some 200's I think.
FREEDGUY
Posted: 21 Sep 2021 at 7:41pm |
Gotcha, makes sense now
. Thanks |
allisbred
Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Posted: 21 Sep 2021 at 8:35pm |
Yes, the 200 has a hinged door. Edited by allisbred - 21 Sep 2021 at 8:37pm |
