Amsoil Products
Jeff-in-Kunkletown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff-in-Kunkletown Quote  Post ReplyReply Direct Link To This Post Topic: Amsoil Products
    Posted: 07 Aug 2010 at 9:18am
Has anyone here ever used Amsoil synthetic oils? I'm thinking about trying them in my personal vehicles. Just looking for opinions, pro or con. Thanks.
Edited by Jeff-in-Kunkletown - 07 Aug 2010 at 9:19am
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2010 at 9:40am
With so many other synthetic oils out there that you can find without the dealer network used by Ams-Oil the question would be is there oil product that good?
 Seems there is a lot more name brand oils that have a good reputation and can be bought in many outlets.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2010 at 10:21am
I use the Amsoil 15/40 in my Chev Duramax. Have put nearly 100,000 miles since started using it and have no issues with it. It comes in a 10 quart jug which works great for me as the Duramax needs 10 qts with a filter change.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2010 at 10:27am
One of the biggest problems with new oil is the zinc/phosphorus reduction to keep converters from going bad.
Valvoline has found a way to keep the zinc/phosphorus in the oil and not in the converter.
No other oil has this at the present time.
Valvoline has this in all of their oils.
trhod12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trhod12 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2010 at 12:29am
I started using Amsoil products in my motorcycle in 2003. It had a clunk when down shifting from 2nd to 1st and up shifting from 1st to 2nd. When I put the amsoil in the bike, the clunk was vitually gone. That made me a believer.
Since then I run amsoil products in everything I own from chainsaw, lawn mower, atv, cars/trucks and tractor and of course the motorcycle.
When you look at the up front cost of amsoil, it can seem like it is a little high, but when you consider the extended oil change interval you can get from the amsoil products match with the correct filter, it will pay for itself in the long run vs conventional oil drain intervals. I love the idea of only having to do 1 oil change per year based on my specific driving styles and vehicle usage.
My entire family started using amsoil products, so I ended up getting a dealership. I don't do it to make money, I do it to get them a good product at a reduced price.
If you decide to go with amsoil, and need some help, shoot me a PM. I can get you the friends and family discount.
Hope this helps.
Blessings,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2010 at 6:39am
Interesting this came up. I just got back from taking Ford's mechanical engine repair class. One of the other guys had just pulled a 5.4 from about a 2 year old F150 for knocking noises. The owner was using Amsoil and was following their extended drain intervals and just changing the filter. The pan was full of sludge that plugged the pick up tube which starved the engine for oil and ruined the rotating assembly. Ford voided the warranty for lack of care. An Amsoil rep came, took pictures, and had the vehicle hauled away all torn down. They were guessing Amsoil paid for a replacement engine.
My take on extended drain intervals is "Not on something you plan to keep long term". If Amsoil is really that much better, why is it so hard to find a dealer for their products? I would think they would want every opportunity to have their products in front of a potential buyer. Either way, if you change every 3K like me, at 170K you can pull a valve cover and find the engine as clean as the day it was built with conventional oil.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2010 at 8:43am
In Iowa, Amsoil is sold at Theison's Farm stores.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2010 at 9:15am
Check out Valvoline's engine guarantees.
https://valvoline.promo.eprize.com/engineguarantee/
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2010 at 11:21am
Use to be a big believer in Amsoil, was even a dealer for a while, but lost interest in there products, and eventually quit using them. One reason was you have to pay amsoil every year to be a dealer, its wasnt enough to just buy there product, that turned me off, and also the more you read and do research you do on synthetic oil the more you find out that there are certain pluses to petroleum based oil and certain benefits to the synthetic, so the best oil to buy would be the semi synthetic, or a blend of each, so you got the benefits of both. But that being said, We have always bought quality oil from reputable dealers in bulk here and have never had an oil realted failure in any product. and I own  alot of diesel  engines, and when we take one apart they are always spotless clean inside, no sludge no build up etc and to be perfectly honest we are not religous about oil changes at an exact hr, if we are near the end of harvest planting etc we go till were done and the fluids get changed, same with the cars and pick ups and big trucks. They are serviced regularly, we use quality oils make sure there topped off and use only quality filters and have O problems, so for us amsoil was just a waste of money. Synthetic grease on the other hand we use  and have been using it for years that can not be beat.
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2010 at 10:12am
They are probably the best oils out there, and if you do a lot of freeway mile driving and you don't have fuel dilution they work on extended drain intervals.
As to what Brian posted, No oil, sythetic or dino, will protect from sludging if you take very short trips all the time.  If the engine is not warming up and staying there for say 30 min. then the water is not being forced out, do not use extended drain intervals with any oil if your vehicle is used like this.
I personally used to use amsoil in most every thing, but have gotten away from them.  Their test(only one that will show test for the most part) always showed other synthetics right behind theirs(especially mobile one).  The way they sell it is a big hassle and is expensive.  I also don't do the highway miles any more.  I pulled their bypass filters off my engine and have switched to mobile one, changing at 5000 miles in the summer and 3000 in the winter.  Its much cheaper, when its on sale at autozone(only thing I buy there)  I also use the mobile one Vtwin in my harley, excellent oil, comparable to the harley synthetic at 4-5 dollars a quart cheaper.  I still get the fuel economy advantage with mobile one as I do with amsoil, and the inside of my engines when scoped are very clean and cylinder wear on my dakota(160000 miles, on amsoil for first 130000, mobile one currently) is negligible, most of the cross hatching still visible when scoped.  Same with my wifes Honda fit(60,000 miles)
  I still use rotella in the tractors/big truck are not running enough miles/hours to warrant the longer life of synthetics but still wanting to change the oil at least every year to prevent corrosion from water condensation.
Edited by firebrick43 - 09 Aug 2010 at 10:15am
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2010 at 7:53am
I have a 1999 Chevy Malibu with a 3.1L V6. Had 32000 on it when I bought it, switched it to 5w30 AMSOIL at that time. Has 230000 on it now with 10,00 between changes. Sludge will form in any engine that is driven short distances and does not have a chance to come up to operating temp and stay there for a period of time. I drive 54 miles to work one way each day. No sludge in my engine
1968 D15D,1962 D19D
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2010 at 8:40am
I also used to be a big fan of Amsoil and ran it in everything I owned until I had to have my 5.7L Chevy engine rebuilt @ 150K.  Always changed oil @ 6K miles with filter every time.  Engine builder said the timing chain was so loose it would have came off very soon and the heads required rebuilding.  Oil pressure was getting close to the red at idle.  Not a fan any longer.  It's expensive.  Shipping is expensive.  Not worth the 6-8 buck a quart cost.
I've switched to Mobil 1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2010 at 1:11pm
I agree with the idea of short trips not getting warm enough. I'm still not a fan of those extended drains they say you can do. I've looked at their bypass oil filters, and they might be a good idea. Anything to filter out the stuff thats smaller than what a normal filter can catch can't hurt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 11:20am
Brian, I had the bypass filters, problem was that they were nearly 50 dollars for the 2 filters on the mount.  I also didn't like the time it took for the oil pressure to come up on the gauge.  I imagine that if you had the electric preoilers that wouldn't be an issue.
This page was generated in 0.367 seconds.
