Almost pulling time.....come on already!!!!
deereequipment1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Topic: Almost pulling time.....come on already!!!!
    Posted: 29 Mar 2012 at 6:10am
Man!
It took months to design and build, but I finally built a V-8 within the casting of the stock straight 4 cylinder.
People are going to be surprised, surprised, SURPRISED!
Edited by deereequipment1 - 01 Apr 2012 at 7:04am
Raised on a CA,WD,D10 & D15.
Now, proudly own and pull a WD45 high crop, WD45, WC,
also own a D-10, D-12, G and a CA.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 6:39am
Whaaaaaat?    Need more info and pics!
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 6:46am
It would be interesting to see this engine, can you post pictures or is this a Top-Secret project??
V8 morph into 4CYL engine, must see, please
Edited by Chris/CT - 29 Mar 2012 at 6:47am
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 7:33am
Chris, that is a pair of 45 engines end to end, I've seen it in person, a nice piece of engineering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 7:45am
OK, I was confused by the first post! Is there a class for that machine?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 7:51am
That ain't a V-8.
Wink
I am a Russian Bot
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 9:20am
would the 6 banger i gots in my wd45 qualify?
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 9:35am
Tractor pullers make a  class for everything !!!!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 7:04am
Ok, i've got to try to get a photo pasted here
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 7:37am
I can't give away too many of my secrets yet.
I think some of my competition reads on this forum.
Its the exact same outside casting as the 226   45 block.
The insides are totally different.
A couple of "true" Allis guys have been by to look the tractor over, and when
I asked them if they could tell me what I did to the engine, they couldn't tell the "real" change. One guessed that I switched things over to Electronic Ignition. Well, yes, that had happened too, so I told him, yup, that's it.
The distributor has a special high output coil, and each spark plug wire is split at the spark plug end, to maintain it's OEM 4 cylinder appearance. There are these avaiation splitters that delay the ohms a split second, to delay the spark timing on the opposite side of the block.
Looking at the block, you can't tell that it is now a V-8.
That was the whole idea with this project.
The boring and degree work took quite a while to get right, but with the
help of two BS engineers, it runs smooth, and has held oil pressure (and together) for
26 hours so far. We haven't put it under a working load yet, all except for the dyno.
Rather than the stock 45 hp, we dyno'd it at 110 hp.
Definitely had to convert it over to 12 volt, because the compression is SUPER tight.
We also fabricated a 1" adapter plate, to bolt to the oil pan to lower it a bit, but not to make it obvious.
This gave us teh needed clearance on the inside for rotations, and for the specially designed oil pump.
We had to tweek the muffler (ALOT) to try to hide the different sound.
The only thing that isn't working, and is just there for looks, is the updraft carburetor.
The 2 barrel unit is up under the hood, behind the air cleaner (out of sight, out of mind).
The only thing that we are having trouble with, is keeping the RPMs down to what the stock block/engine should have.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 7:47am
    Loof lirpa, to you too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 7:53am
Interesting. You'll be pulling in a class by yourself it sounds like. Any Antique club that has a good tech inspector will determine something is up by the different exhaust sound and the 1inch thick girdle plate, let alone the fact the carb doesn't do anything and the governor doesn't work. Better keep corn picker side shields on it to hide things. Sounds like quite a project and hope it stays in one piece for you. The HP of 110 has been met many times by other Antique Pullers that have bored and stroked to 400 cubes or more with 4 cylinders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 7:55am
Can't wait to see pictures of this engine, please post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 8:22am
yes, but this is just the start.
carburetor upgrades, room for larger sleeves, cam work,
head work,
Are ALL still in the plans, once all is tested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 8:35am
With a three inch bore on eight cylinders and stock 4 1/2 inch stroke that figures 254 cubes, right??
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 9:11am
cam shaft changed head changed to i would think must not be running weater in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 4:34pm
Well, like Gary in da UP said......
It IS April Fools day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 7:35pm
Yup April 1 st - fools day
Rod B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 11:47am
now you can go pull in fantisy land with pankey.
