Allis-Chalmers 17 mounted corn picker
AC1945WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC1945WC Quote  Post ReplyReply Direct Link To This Post Topic: Allis-Chalmers 17 mounted corn picker
    Posted: 14 Jan 2021 at 1:47am
I purchased a model 17 Allis-Chalmers two row mounted corn picker a while back and I was told it would fit on a WD45 but I know for sure it was made to fit the D17. Will this picker fit my WD45 or should I look for a D17 to mount it on?
AC1945WC
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2021 at 10:22am
It may fit BUT will it work would be my question. I would go for the D-17 if it were me.
also would the offset seat be a problem on the wd-45? just askin!
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2021 at 5:15pm
If you have the brackets it will fit.   In heavy corn you will wish you had the 2 speed power director like a D17 has. I had a 227 JD picker on my 45 several times. The offset seat was no problem, but I had a gear for a 60 JD on the PTO shaft. It needed a smaller gear to speed up the picker, 45's travel faster than the picker could handle the corn.     Have fun with your picker.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2021 at 5:30pm
Sounds to me like you have an excuse to buy another tractor.Wink
Edited by bigal121892 - 14 Jan 2021 at 5:30pm
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2021 at 7:28pm
I think there was a kit to move the steering wheel over to allow using center-based pickers.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2021 at 8:46pm
Seat had a hinge that offset it,           MACK
