Allis WC |
drak
Topic: Allis WCPosted: 01 Jun 2017 at 12:30am |
Can any one explain what is the purpose of the stop bracket on the clutch pedal of my 35 WC ?
I often wonder what could its purpose be other than to burn the clutch out
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2578 |
Posted: 01 Jun 2017 at 6:00am |
The one to lock the clutch disengaged? Its for hand cranking to start. Always always always start a tractor with the clutch disengaged.
AaronSEIA |
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11803 |
Posted: 01 Jun 2017 at 6:02am |
Also to disengage the belt pulley when hooked up to threshers and other equipment.
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 01 Jun 2017 at 6:29am |
or burn out release bearing if run in disengaged all the time on a bearing that has been in tractor forever and grease is dried up in it, |
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
MACK
Posted: 01 Jun 2017 at 6:43am |
They had a grease zert in them. MACK
drak
Posted: 03 Jun 2017 at 11:55pm |
Hi Aaron thanks for your advice, but why do you advise to start the tractor with the clutch engaged ?
yes its possible with the WC as a lock is provided, but on a B or C for instance there is no lock so its not possible to crank it with the clutch engaged, unless you have someone who can assist !!
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Posted: 04 Jun 2017 at 12:04am |
I've seen B's with it, mine included.
drak
Posted: 04 Jun 2017 at 3:04am |
Oh.......... looks like I need to eat my words
Thanks Creston
what66
Joined: 03 Sep 2013 Location: linden,ia Points: 167 |
Posted: 04 Jun 2017 at 6:41am |
My 47 C had a clutch prop when I got it I took it off when I put a pump on the crank.
By the way, it keeps the clutch Disengaged not engaged. |
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
Posted: 04 Jun 2017 at 7:13am |
Our '53 DW had one also.
Dusty
CTuckerNWIL
Posted: 04 Jun 2017 at 1:13pm |
Pushed in is DISengaged and the tractor can't run over you if it happens to be in gear. Also, if you plan on long term storage, you can lock the pedal down so the clutch plates can't rust together. |
Dakota Dave
Posted: 04 Jun 2017 at 2:41pm |
most hand crank tractors from all manufactors had a clutch release lock. It's there so when hand cranking it your not turning the input shaft to make hand cranking easier. In cold weather with the old 90 or 130 oil there was significant drag with the clutch engaged. If you had a belt pulley you had to lock the clutch down to start in any weather or you were trying to turn whatever it was attached to. I can tell you from personal experience you weren't able to crank it over and turn the whole sawmill at the same time.
drak
Posted: 04 Jun 2017 at 11:42pm |
Now that makes complete sense Dave
Many thanks for the clear explanation |
