Allis Tug
James Coons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Coons Quote  Post ReplyReply Direct Link To This Post Topic: Allis Tug
    Posted: 22 Nov 2015 at 10:51am
Got a call this weekend from a guy that things he has a small Allis tug.  For those of you that have one or have seen one whats the best way to identify them?  Do they have a data plate somewhere?  We're supposed to get together next week to take a look at it.  Any info to help identify whether its an Allis would be appreciated!  From what he described it sounds like it may be one like this:
Edited by James Coons - 22 Nov 2015 at 10:52am
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 12:27pm
I don't know but Larry Swenson could fill you in I bet. No Sunday calls.
George R. (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George R. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 2:57pm
James,
I worked for North Central Airlines in the mid-sixties as a station agent (ramp rat) at O'Hare, Milwaukee and Minneapolis. I do remember some of the older tugs pulling baggage carts were AC and probably bought as war surplus. I think they had a continental four cylinder flat head. I could be wrong on that its been over 60 years ago and the memory has faded some. At that time they also had some Clark tugs as well but they were quite a bit newer. I can't help you on the ID tag location, wish I could.
My tractor is not leaking oil, it's just marking it's territory!
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 3:38pm
I think the tugs are a Buda product and the ones that I have seen have the 153 cu.in engine which is the four cylinder version of the 230 cu.in. 6 cylinder.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 9:47pm
Clark made a whole lotta aircraft tugs, and if you look really close, you'll see that tugs sit on a platform that is surprisingly similar to a forklift... and that's NOT a coincedence.
This is clearly a Buda engine... I'd bet my lunch-money that if one were to compare it to AC forklifts matching it's vintage, that it's probably the same platform, just with the operating station reversed, a few controls changes, and of course, no hydraulics.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 10:04pm
I think my neighbor has one of those, looks the same. he wanted to know if I wanted it and I said no....at the time! gonna check to see if he still has it!
EdW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EdW Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 5:53am
I have an Allis tug identical to that one. Mine is a model TG-24. Mine does have the G153 engine with a s/n tag behind the distributor with an Allis charmers serial number. It also has a plate riveted under the dash that says Allis charmers and gives the model ans serial numbers. They were built at the Buda plant in Harvey, Il. I have a piece of literature from Allis that shows the different models of tugs that they produced with the specifications. PM me with your address and I will copy it and send to you.
EdW
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 5:59am
man that's cute ! If I can say that word......
hmm..G153, same engine as my Cockshutt 30 donor has. Now if you want a REAL challenge swap  the D(iesel)153 from my A-C forklift,rebuild then install into the tug.
yup, wife would NOT be happy seeing the tug show up...but it is nice....
Jay
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 7:27am
That's Bob Vanderploegs Tug. Found for him in LA Ca. area. Was being used by some circus event group down there. $500.00 not a bad deal . That thing down right flies!!!
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
