Allis Trip Plows Rebuild Project
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Topic: Allis Trip Plows Rebuild Project
    Posted: 14 Jun 2020 at 8:30pm
Hi everyone, I got another project (or projects)! This may be a bit of a long term project, as I have enough in the works already, but when certain things come up for sale you just have to jump at the opportunity and dig into them a bit....
Be sure to let me know what you think, and add lots of advice on plows, as I am basically a rookie when it comes to these things!
Thanks
[TUBE]PDbQ-vwJPos[/TUBE]
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 7:38am
Good project. Your right, when opportunity knocks you have to answer! I've made good progress lately on the projects list, long term included. Of coarse there is the Amana show next weekend.....
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 10:46am
Take that hitch and put it in an electrolysis system and it will clean it up like it was never rusty at all  Arm and Hammer washing soda and water, hook up a battery charger and watch it work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 7:30pm
This would be a good thing to try electrolysis on.  I've been kinda wanting to try it as I have not done so yet.  To be honest, I'm a little scared to do it with mixing electricity and water and all.
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2020 at 8:00am
Perfectly safe Just get everything in place and then turn on the power, you are only dealing with 12 volts or so.  I just took a old carburetor that was rust from years of sitting, could move the seat to remove, put it on solution for two days comes right out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2020 at 8:49am
 The only thing to be concerned about, is build up of gasses. Do this in a well ventilated area and you won't have a problem. Contain the Hydrogen and Oxygen that escapes from the process in a small air tight area and a spark from your battery charger could remove a well built building. Shocked
 I have read of guys digging a pit in the dirt, lining it with plastic and cleaning big parts that won't fit in a 5 gallon bucket or a 55 gallon barrel.
 I used a 55 gallon barrel for the block  from my 35WC and it came out nearly as clean as a baked and shot peened block.
