Allis steering universal joint
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Allis steering universal joint
    Posted: 15 Oct 2016 at 10:34am
Hi guys is there absolutely no way around buying a whole new yoke assembly. Is the cross itself just not available?
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 11:22am
whats it on??
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 11:26am
I have two bad ones on a D-17
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 11:37am
  If yours is like the one on my WC, the thing is welded and you would almost need a fixture to hold it in place to put it back together.
 I bought a new one that wasn't exactly like the original for my 35WC, then found one in the junk pile that came off a 60All Crop combine. The only difference is the combine uses a key on one side so I had to drill a hole for the pin on that side.
Edited by CTuckerNWIL - 15 Oct 2016 at 11:39am
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 6:59am
I have rebuilt and used on the shelf.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 7:37am
It hasn't been that many years that I put all new on the 15 II?
are you sure Brenda at Sandy can't wrestle you some up.
Edited by Dave H - 16 Oct 2016 at 7:39am
alleyyooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alleyyooper Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 7:02am
Give the U joint store a try.
http://www.theujointstore.com/
Al
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 12:06pm
If you yokes are ok you can get new ujoint kits. I have them on the shelf.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 7:41pm
get new crosses and bearjng caps for my 45,gas and diesels.....s
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 9:56pm
What's your price Lon? I'm having same issue
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 8:45am
$40.00 plus the ride.
Thanks
Lon
Post Options Post Options   Thanks (0) Thanks(0)   Quote alleyyooper Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 10:08am
Oh come on try the Joint store most expensive there is 20 some odd dollars.
http://www.theujointstore.com/tus190.html
Al
