Allis steering universal joint |
nowaktj
Joined: 13 Dec 2009 Location: Elk River, MN Points: 735 |
Topic: Allis steering universal jointPosted: 15 Oct 2016 at 10:34am |
Hi guys is there absolutely no way around buying a whole new yoke assembly. Is the cross itself just not available?
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
HD6GTOM
Posted: 15 Oct 2016 at 11:22am |
whats it on??
nowaktj
Posted: 15 Oct 2016 at 11:26am |
I have two bad ones on a D-17
CTuckerNWIL
Posted: 15 Oct 2016 at 11:37am |
If yours is like the one on my WC, the thing is welded and you would almost need a fixture to hold it in place to put it back together.
I bought a new one that wasn't exactly like the original for my 35WC, then found one in the junk pile that came off a 60All Crop combine. The only difference is the combine uses a key on one side so I had to drill a hole for the pin on that side. Edited by CTuckerNWIL - 15 Oct 2016 at 11:39am |
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2037 |
Posted: 16 Oct 2016 at 6:59am |
I have rebuilt and used on the shelf.
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3591 |
Posted: 16 Oct 2016 at 7:37am |
It hasn't been that many years that I put all new on the 15 II?
are you sure Brenda at Sandy can't wrestle you some up. Edited by Dave H - 16 Oct 2016 at 7:39am |
alleyyooper
Posted: 17 Oct 2016 at 7:02am |
Give the U joint store a try.
http://www.theujointstore.com/ Al
JimIA
Joined: 12 Sep 2009 Location: Castalia Iowa Points: 1983 |
Posted: 17 Oct 2016 at 12:06pm |
If you yokes are ok you can get new ujoint kits. I have them on the shelf.
j.w.freck
Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
Posted: 17 Oct 2016 at 7:41pm |
get new crosses and bearjng caps for my 45,gas and diesels.....s
Scott B
Joined: 14 Sep 2013 Location: Kansas City Points: 1051 |
Posted: 17 Oct 2016 at 9:56pm |
What's your price Lon? I'm having same issue
D17 Series 1
Allis B- 1939 Allis B- 1945 |
Lon(MN)
Posted: 18 Oct 2016 at 8:45am |
$40.00 plus the ride.
Thanks Lon
alleyyooper
Posted: 18 Oct 2016 at 10:08am |
Oh come on try the Joint store most expensive there is 20 some odd dollars.
![]() http://www.theujointstore.com/tus190.html Al
