Allis G Spark Plug Problem
ogeechee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ogeechee Quote  Post ReplyReply Direct Link To This Post Topic: Allis G Spark Plug Problem
    Posted: 14 Nov 2015 at 1:25am
The Manual calls for an AC 45 plug. Is that the same as an AC R45? I appreciate your response. Dan
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 4:45am
That is the replacement.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 6:11am
I'm 'thinking' the R means it has a built in resistor  for noise suppression ??
Be nice to KNOW though.....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 6:15am
The "R" stands for a Resistor plug. Although it probably wouldn't hurt the ignition system any because its a Distributor, the plug that works quite well in a G model w/Continental is the Autolite 295's. As a matter of fact, the Autolite 295's work good in a lot of the older AC machines. The Autolite 303 is an optional plug, and is a fuzz colder than the 295. Worn engines work better with the 295's mainly because its a little hotter plug... HTH
Steve@B&B
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 8:24am
Iv'e found this to be helpful.    autolite application look-up
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 10:09am
When we sold them we lived with the AC-45, AC-47, and AC-48, depending on how "hot" a plug you needed - we used the AC-48's in the older machines.
However, that was in the 40's 50's and very early 60's.  In today's market I have heard very interesting reports that the AC plugs are not all that good.
Listen to what my friend SteveNJ says.  He is our on line electrical expert and knows from deep experience.  I would fully rely on him.
Take good care of your G.  You have a Classic Allis Chalmers tractor.  The best plowing tractor I sold.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote ogeechee Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 11:58am
I appreciate all of your responses and thanks for taking the time to answer my questions. Autolite 295s ordered.
