Allis g narrow rear end
Stookless View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stookless Quote  Post ReplyReply Direct Link To This Post Topic: Allis g narrow rear end
    Posted: 02 Jan 2020 at 6:46pm
I bought a partial g last weekend. It has a narrow rear end. Does anyone know if the g came from the factory with a narrow rear end? Or was this a mod done later?
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 7:45pm
G's only came one way, ones that were narrowed or widened were done afterwards
pictures??
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 9:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 4:50am
G's were one of the most modified tractors, ever.  I read a quote, somewhere, that they (the modifiers) would either make them 3 rows wide, or so narrow, that the tires would fill your pockets with dirt...Wink
lbr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lbr Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 5:03am
The G's were narrowed up around the midwest to sow wheat down a wide row of corn. My father talked a lot about this when they got away from horses they narrowed up there G to run down the wide row of corn sowing wheat with a single row drill. He also said it wasn't a fun job getting hit by the corn ears and leaves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stookless Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 11:28am
I will get a picture of it. I would really like to change it back to original. Would anyone be willing to trade axles or rolling chassis with me? Iij want to mow with it and I'm worried about stability on hilly ground.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 1:21pm
The G did have two different length axle housings from the factory. The shorter version had a much lower amount manufactured. Still quite a few out there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stookless Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 5:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 6:28am
Edited by Dick L - 04 Jan 2020 at 6:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stookless Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 7:30am
That appears to be a standard rear end. I have a 2nd g like that. I have been tracking down the parts I need. That's no easy task.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 10:27am
I put the pictures on so you could see the differences in the length of your shorter axle housings and my longer ones. I didn't know that you had one to compare yourself. Yours are like all the short factory axle housing I have seen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 10:28am
OK, I have to ask, just how narrow IS a narrow G ? Stock ones give 36" track....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 10:32am
I have one tore down that I will never get at making whole again that I would take offers on.
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 11:02am
I can relate to lbr'(Indiana) memory as we had two narrow, wheelless, walk behind, drills for sewing wheat between rows of corn.  At that time most corn rows in central KS were 42". They were stored upstairs in our grainery; any use was before 1938.  At a GOO in Lagrange, IN decades ago an enthusiast from southwest IN told me of narrowed Gs in his area; three small AC dealers had gone together and had a welder-machinist modify an estimated three dozen Gs primarily for this use.   Herb(GA)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stookless Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 11:25am
Do you have any pics of the g? Is it complete? How much would you want for it?
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 7:59pm
One of my G's is narrow, tires barely hit the fenders.
ALLIS EXPRESS!
This year:
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 8:16pm
I have one of the narrow up G also
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stookless Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 11:23am
My narrow g measures about 33 inches hub to hub. My other g measures 48 inches hub hub to hub.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 11:58am
hmm 33", what's the 'track' ( center of tire tread to center of other tire tread' ) ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stookless Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2020 at 6:52pm
The g has a lot of adjustment on wheel spacing. My narrow g currently measures 38" center to center.
