Allis G - N62 Oil Filter Mount
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Topic: Allis G - N62 Oil Filter Mount
    Posted: 28 Sep 2016 at 10:33am
New to Allis G. The oil filter mount is not tight in the block. I don't find any method to secure it. Is it just a press fit into the block? Has anyone had this situation and if so, what would be a good solution?
I think JB Weld may be a little to permanent in case the mount broke and had to be replaced.
Thanks,
Kent
Edited by K-Mo - 28 Sep 2016 at 10:38am
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 10:49am
Go ahead and pull it out, stake it with a punch all the way around, then re-set it in the hole with a mallet and a wood block. It should be fine, you could also set it with some green loctite, but get it where you want it before it sets.
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 12:40pm
Good suggestions. I like the Loctite idea. I'll check the specs on the green. If I remember correctly some Loctite formulas can be loosened with a specified amount of heat.
I think the oil filter mount is pot metal. It would be my luck to break it while trying to use a punch on it and drive it into place.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 1:12pm
you don't have to hit it hard, you're just trying to give it some bite in the hole
Ford 345C TLB
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 1:28pm
Don't use the Loctite ,get the Right Stuff ,it will seal it and help hold it .Still stake it
nonetheless ,still dead.
