Allis G/Continental N62?
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Topic: Allis G/Continental N62?
    Posted: 13 May 2017 at 6:54am
Question about the installation of N62 crankshaft thrust washers.
  The only reference I can find is from the Allis G SM. It states, "Both thrust washers should be placed on the shaft with the bevel on the inside diameter towards the first crank throw of the shaft."
  To me, the first throw would the the rod journal. It would seem more logical to reference the front main bearing. Are they calling the main bearing journal the "first throw"?
  Should the thrust washers be installed with both bevels toward the rear of the engine?
  Should they symmetrically installed with both bevels toward or away from the main bearing?
Kent
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 10:22am
the bevel is away from main cap.It is for radius clearance
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 1:55pm
Steve,
That's a clearer explanation than the statement in the book.
Thanks,
Kent
This page was generated in 0.316 seconds.
