allis d15 series II REAR TRED ADJUSTMENT |
cobra ![]() Silver Level ![]() ![]() Joined: 16 Oct 2011 Location: p.e.i. canada Points: 66 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Oct 2011 at 3:45pm |
HOH DO U ADJUST REAR TREAD WIDTH ON A D15 SERIES ii IT DOE NOT HAVE POWER ASSIST IWAS TOLD IT HAS A SET SCREW ??? THANKS
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7528 |
It is does not have power adjust rims, the wheel tread cannot be adjusted.
D-17_Dave ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
If the rims have different offset centers then you can swap sides.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Somebody replaced the original rims with combine rims I would guess. The rims might be offset so you can switch the rims to the other side. In order to adjust as original, you would need the PAW rims.
