Allis cotton days
Post Options Post Options   Thanks (1) Thanks(1)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 7:57pm
Basically pickers are much more complicated than a stripper. Creston only had stripper machines. He has one with a header that looks like a pickers but it is not . Allis promoted strippers as a better more economical way of harvesting cotton. Another company (green) wanted the more complicated system that needed more replacement parts and service. This other company squashed research that Basically wrote the end of the stripper. Pickers produce a slightly cleaner product and can go through the field several times. Creston knows a lot about these machines and hopefully he can chime in. If you get a chance and he does this again definitely get out there to see this in person. Hopefully someone made a video that can be posted on YouTube of Creston explaining the machines and the process.
There are different varieties of cotton for both the pickers and strippers. Picker cotton is taller, usually irrigated and out produces stripper cotton. Stripper cotton is shorter and usually used in dry land farming. Produces less but much less input
Edited by Pat the Plumber CIL - 16 Nov 2025 at 8:02pm
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 9:45pm
Check out Wild West Farmer on YouTube!  They run 3 JD strippers that are 25 years old, still use boll buggies and module builders!  Says it is way to expensive to get a new one that puts out bales!
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 4:52am
All of those old stripper teeth also have other uses, too...Wink
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 10:21am
There might even be one of those tree stands hiding here somewhere. But I believe that is picker spindle. Or do strippers use spindles too? Since picture of Creston's machines here is as close as I have been.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 11:56pm
Here are a couple clips from the show. It wasn't much, but we had fun! About 150 combined guests from both days. We had guests from Arizona, New Mexico, Texas, Oklahoma, Nebraska, North Dakota, Minnesota, Wisconsin, Illinois, Iowa, Indiana, Ohio, and Ontario. Everyone insisted I need to do this again next year, so that's currently the plan. Going to plan on November 13th & 14th, 2026.
A short clip of field demos and the kids' cotton picking contest:
This one is a walk-through history of the models of cotton strippers Allis produced:
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 59 minutes ago at 5:43am
Pat, thank you for sharing info & photos. Will put this event on my calendar for 2026 & hopes to attend?
Creston, thank you for sharing a marvelous history of cotton production, both its industry & AC’s participation. I had read about AC using their gleaner machines as base models for cotton. Love hearing the G226 & GM250s running in the video & imagined smelling their gasoline exhausts? Terrific job!
This page was generated in 0.057 seconds.
