Allis Chalmers WD45 with Factory Power Steering
Blake_AllisMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers WD45 with Factory Power Steering
    Posted: 29 Jul 2017 at 12:06pm
I was wondering what a guy should pay for a WD45 with factory power steering. Everything works as it should. Good rims. Tires have about 1/2 tread all the way around. 3 bolt wide front end. Hydraulics work. Sheet metal is in fair shape. Good fenders. Older guy uses it to run a rotary mower. Slight leak in the manifold. Looking for some answers. Thanks in advance.
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
1977 5020 4WD Serial Number 1
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 9:08pm
Sounds like you have a typical $1500 to $2000 tractor.  The P/S is a BIG plus as far as I'm concerned though, so I'd go maybe up as much as $2250.  3 bolt means it's an early one but that doesn't mean anything.  It's just that the 4 bolt front is stronger if you're going to use it with a loader.  HTHs......
Harvey/pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 9:26pm
Describes mine to a T, gave $1000.oo...Harvey
JayD-17(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayD-17(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 11:02pm
I concur with 2250 estimate given the tires are at 50%....2500 tops if you really really wanted it.
Under current market conditions, a complete factory power steering assembly seems to only add 4 to 500 dollars in value to the tractor. Separately though, the right guy may give you as much as 750 for one.
At an auction last summer, there was a narrow front WD45 with factory PS, stem to stern resto on it with new rubber all around. Claimed to of had 7k invested in it, and it looked it. Sold for $4000.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 11:47pm
Had a hard time getting $900 out of the one I had.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 9:28am
Thank you all for the comments. The tractor will be getting delivered sometime this week to my place along with two Allis Chalmers rotary mowers. Have a great weekend all!
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
This page was generated in 0.398 seconds.
