Allis Chalmers WD45 Diesel project |
Post Reply | Page 123 8> |
55allis
Orange Level Joined: 30 Jun 2020 Location: Southwest IA Points: 545 |
Posted: 01 Jul 2020 at 10:16am |
Hi to all, just got me a nice WD45 with a D19 diesel repower engine in it. It has been setting for about 20 years in a machinery shed. Put new diesel in it and it started right up.
Got it to a shop so I can work on it and so far I took it in to get rid of the fluid in the rear tires and change the oil. Would post a picture but it won’t load. |
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3445 |
Good luck with the tractor and welcome to the forum.
55allis
Thanks(1)
Got to looking at it and the radiator and the diesel pump are leaking.
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7204 |
Welcome to the world of buying old tractors. Not trying to bring you down but you WILL find more things wrong with it the more you look. Deal with them when you stumble across them.
55allis
Yes I know that from experience!!
Does anyone know how hard it is to take apart and put together those pumps are? |
DSeries4
These pumps are NOT for an amateur! Send it to a shop that knows these pumps.
55allis
My cousin might be able to help on the pump so I might be in good luck. I got the tractor from him.
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8167 |
55allis,
Welcome! Glad the tractor is running. As mentioned they tend to mark there territory. Every thing about a diesel is a little more complicated than a gas job. But you have a rare tractor. Under 7000 made I believe. You might need to reduce the picture size to around 800 x 600 pixels for it to load better. Regards, Chris |
55allis
Ok thanks
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7943 |
Good looking tractor
55allis
How thick is a late d17 diesel head gasket?
MACK
.065. MACK
55allis
Ok thanks Mack. it has d17 pistons and the valves hit the pistons so I think a thicker head gasket will fix that problem.
Thanks!! |
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33637 |
Have you physically checked to see by rotating engine and then checking the valve for movement at tdc of engine with the valve open?
55allis
When my cousin overhauled it 30 some years ago he put d17 pistons in it and so he drove it 10 miles right after he overhauled it and it bent a few pushrods, so he was in a hurry to use it and retarded the camshaft and fixed all the pushrods it bent
Now if that explains what happened |
MACK
Don't think there is a thicker head gasket + that would increase the chances of blowing head gasket. MACK
MACK
Machine some from top of pistons. MACK
55allis
I think it will be fine with a d17 head gasket besides they are a bit thicker.
MACK
All 230-262 diesel head gaskets are the same thickness. MACK
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29773 |
There must be a difference in cams for the D17 pistons to hit in a D19 diesel. The later D19 compression ratio is 15:1 and the D17 is 15.7:1. Machining pistons would fix it. Of course I have little experience in those engines........ Looking at the parts page it looks like the cam changed and when using the new cam you had to change to newer pistons. I'm just babbling for my own edjamacation.
Wink I am a Russian Bot |
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7981 |
Do the diesels have flat surface where valve sets requiring specific stand out? Someone put seats in my 8070 before I got it and didn't set them down...had valve marks in carbon on 4 pistons.
Lonn
I believe they are flat
Sugarmaker
55 allis,
I can see you have some experience in these engines and that's good. I do not. A good friend and good mechanic on these 45D engines gave me advice on them. If you want to chat P.M. me. Thanks for posting the picture of your tractor! Regards, Chris
Albert
Silver Level Joined: 11 Sep 2009 Location: NW MO Points: 410 |
The AGCO head gaskets had a sheet of paper inside them on the piston machining needed. AGCO has killed the head gasket but Tony at Tony's tractor has one left of the AGCO gaskets left'
Albert |
55allis
Ok but already got one coming
Thanks |
55allis
Got the one rim and tire put together and painted [IMG]http://
55allis
Here is the picture, it didn’t work the first time |
55allis
Here is a better picture |
IBWD MIke
55, that looks great!
Sugarmaker
Nice big 16.9's on the 45D! I like it. Wheel looks good!
Thanks for posting. Regards, Chris
