Allis Chalmers sickle bar mower
Jefffafa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jefffafa Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers sickle bar mower
    Posted: 13 Nov 2025 at 6:00pm
Hi. I have an allis Chalmers 80R3 sickle bar mower. I was wondering if 10w 30 or 40 oil would be good to use in the gearbox?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2025 at 7:32pm
I would use 90w in it. Tracy.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2025 at 8:12pm
80/90W Gear oil. Tractor supply carries it in two and five gallon containers. Auto parts stores have it in quarts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jefffafa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2025 at 12:31am
Ok thank you 👍
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2025 at 5:17am
If it leaks some go with some or all John Deere corn head grease.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2025 at 6:39am
All good suggestions
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2025 at 11:58am
A couple of things on those Twin-Wheel drive mowers:  #1. Keep the sickle head bolt TIGHT. This bolt must be a grade 8 quality. #2. Make sure the serrations in the bushing this bolt clamps thru are CLEAN when assembling. #3. Keep the cross-arm snug against the bushing. Any looseness in any of these parts leads to quick destruction of said parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jefffafa Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 2:32am
Ok thank you. I'm just a dabbler with tractor stuff. I have a Kubota L3400 compact tractor with a few attachments, and a neighboring farm had the sickle bar mower, which has been sitting outside for maybe ten years not being used, so they said to try it out. So I'm trying to get it back in running condition hoping to buy it. I'm trying to get all the adjustments as close to what I think they should be, to fit my tractor. (they didn't have an owners manual since they bought it on consignment). On a short trial run, I thought it mowed half decent...Does anyone know what it may be worth?
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 2:44am
I just bought one last summer that need work for 300
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 40 minutes ago at 9:37am
Several years ago I asked the same question on here. One member recommended, straight 30 weight non detergent oil. That oil has worked well in the mower.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 48 minutes ago at 10:29am
I still use 30 wt. in my 80R mowers.
From the lubrication chart on page 4 of the 80R manual: Drive housing capacity, 1 qt. SAE No. 20 or 30.  Do not let oil level get below or do not fill above drive shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 58 minutes ago at 1:19pm
dont mix gear lube and engine oil... Use one or the other.. Always flush if you change... Years ago i had a mechanic top off a dozer final drive with 15W40 in a 80-90 wt gear case.. Turned it into a black goo after a couple weeks.
This page was generated in 0.045 seconds.
