Allis Chalmers S/C spring tooth cultivator
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers S/C spring tooth cultivator
    Posted: 15 Nov 2015 at 1:54pm
When the D17 was introduced Allis Chalmers introduced a 10 , 12   and 15 foot s/c spring tooth cultivator for the D14 and D17 also the WD and WD45.
Does anyone have pictures of these cultivators and was there a model number.
thanks
Edited by WD45 - 15 Nov 2015 at 7:57pm
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 10:04pm
Fred..a few manuals
click here
click here second one
third one click here
says Model TM-16D or TM-16E
Mike
Dave (NE) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 7:49pm
Well, I don't know if this is what you were looking for, but here is a 12' snap coupler spring tooth I picked up a couple years ago. I then acquired a 16' one also. Never seen a 10' one, but heard there were 8' ones (also never seen one).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 7:59pm
And here is what I would call a snap coupler field cultivator. It is 8' wide.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 8:40pm
Thanks Dave
The first cultivator - first time seeing one like that. Was this unit sold by Allis. The second cultivator dad bought a used one like that one in 1961 but the C shanks had been changed to the new style which was a larger C which was used on the cultivator that I was looking for. A neighbour had a 15 ft s/c cultivator back in the late 50's along with a 15 ft Allis disc to pull behind his new D17. Wow as a kid then the D17 was some big tractor which we could only dream about.
Edited by WD45 - 18 Nov 2015 at 8:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 9:53pm
Well, they are both Allis. The spring tooth still has a decal on it saying Allis. Can't recall if the field cultivator still has a decal on it. It may have been manufactured by Oxnard, though.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 10:16pm
We had one just like that 2nd one behind our WD45. Worked well. Opened up the governor lots! Same as you Fred we replaced all the teeth with the bigger wrap around "C" style. The other ones all broke off in the Grey county rock patch. LOL
Edited by Ed (Ont) - 18 Nov 2015 at 10:19pm
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2015 at 6:20am
I have one like the second one. Got a couple broken teeth also. Took the center section off an mounted hiller discs on it. Works great for cultivating potatoes.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2015 at 8:34am
We had one like the one shown on the second link above.
TM-16D or E is the form number of the book not the cultivator model.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2015 at 9:33am
Is one might be more of a heavier unit then you are talking about.
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2015 at 9:48am
I also have one like the one Dave calls a field cultivator. Mine had been used behind a front mounted row crop cultivator to remove the tire tracks. It has been converted to a 3pt because I no longer have a SC tractor.
