Allis Chalmers model c wiring harness |
Post Reply |
soppins
Bronze Level Joined: 02 Jul 2019 Location: Texas Points: 7 |
Posted: 21 Aug 2019 at 8:51pm |
My son is restoring an Allis Chalmers model c for his 4-H Ag Mechanics project. He is trying to find out how they ran the wiring harness from the factory across the block to the front. Also was there two insulated posts on the radiator to attach the headlights or just one on the left side. Thanks for your help.
Lon(MN)
Orange Level Joined: 11 Sep 2009 Location: Elk River,MN Points: 1905 |
One insulated post on the left
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11549 |
The wiring harness ran from the instrument box, under the Battery box (if equipped) behind the air filter, dropped under the Carburetor to the Generator. From there, the Headlight lead went to the insulated junction attached to the fan shroud, through a rubber grommet in the fan shround out to each Headlamp. The Mag or Distributor circuit went up and around the front of the engine (valve cover area) around the corner to the Mag or Distributor. (whichever it was equipped with.) If it had a Battery ignition (Distributor) that circuit ran to the negative side of the coil which was mounted off of the Distributor drive via a coil bracket. The positive side of the coil went to the Distributor. (Positive ground systems) HTH
Steve@B&B
Gerald J.
Orange Level Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
The shop manual should have some details:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf Gerald J. |
Post Reply | |
