Allis Chalmers CA
NCACCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCACCA Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers CA
    Posted: 28 Mar 2018 at 3:10am
Hey guys I'm new and I just got my first tractor and its a CA and I'm trying to get a list of attachments I could get for it and I just cant seem to find it. One member had a list but nome of the photos load so I can't seem to find anything from it.
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2018 at 5:38am
Welcome to the site.  You can find lots of good information here.  Some of the attachments include a blade, plow, disc, mounted cultivators, rear cultivators, dirt scoop, rotary hoe, and planter in snap coupler.  If you CA is a pin hitch it is harder to find attachments, but it can be converted to snap coupler.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2018 at 8:26am
Allis implements are somewhat difficult to come by. If you can't locate those you need, it con ne converted to a 3 point and you can readily find whatever implements you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2018 at 1:09pm
Here's a list of the factory built CA implements I have;
#52  2 bottom plow
#54  2 bottom spinner plow
#20  disc harrow   (available in various sizes)
#40 disc harrow
2 row drill planter
9 run All-Crop-Drill
2 row  row-crop cultivators
5 shank coil spring field cultivator
7 foot spring tooth field cultivator
2 disc plow (Athens built for Allis)
4 disc tiller (Athens built for Allis)
curved shank Sub-Soiler
7 foot front mounted Snow Plow
Trip Bucket Front end loader
Rear blade
Dirt scoop
#5 sickle bar mower
#10 post hole digger with the CA mount
Carry-All
Things I know of but don't have;
#30 disc harrow
spring tooth harrow
2 row rotary hoe
1 row cotton picker
Maybe some other things as well. So you can see that Allis Chalmers built or sold any implement that you could possibly need, most everything was available for the Pin-Hitch tractors, then later they were also available for the Snap-Coupler equipped tractors. This was in my opinion the best lifting and draft sensing system of any tractor of it's time. Searching for the correct equipment to match to your tractor is part of the fun of a unique tractor of the Allis Chalmers brand. If you have the desire to ruin you tractor with a 3pt why did you not buy a Ford or something else?
Edited by PaulB - 29 Mar 2018 at 6:34am
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2018 at 6:04pm
Paul B "IS THE MAN WHEN IT COMES TO THE CA ALLIS". Both in the field and on the pulling track.
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2018 at 7:38pm
Welcome,  I have a CA with pin hitch, as AC equipment is scarce around here, I have been messing around with making a 3 point adapter.  Which end of NC  are you?  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2018 at 8:12pm
well, the first thing to know is what type of hitch / hydraulics / arms are on the back now ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2018 at 8:24pm
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2018 at 10:15am
TMILLER There is more to making a three point hitch than meets te eye .Made one for my B  Works ok with finish mower.If you look at a ford hitch is under axle  and third arm is not to high above it.I could not get close to these measurements.With custom built ones hitch is so far behind axle  you need a lot of front end weight.Picture of mine on customized B . Hope you have good luck .PS  I am in sunshine  n c
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2018 at 8:26pm
wfmurray, I'm  currently not going to hook to any pto equipment, just working on attaching a 3 point disk.  Will post a couple of pics when I am finished. Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCACCA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 10:55am
Hello everyone thank you so much for the replies! I have a 3 point hydro hitch. So I guess it will be easier to get attachments then. By the way my first time ever owning a tractor. So any and all knowledge that I can learn would be great!
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 11:41am
If you are looking for implements, I have a 7' CA20 pin hitch disc I would sell. If you are interested, pm me.
